maxhap
August 5, 2015, 9:31pm
1
Sorry for the simple question but how do I set the world position of a PxRigidBody that has previously been created.
All the example I look at set the position when the object is created but I would like to set a new position to click objects in my scene.
I have tried the following but the objects remain at their original position.
physx::PxVec3 pxVec;
pxVec.x = position->x;
pxVec.y = position->y;
pxVec.z = position->z;
physx::PxTransform positionTrans;
positionTrans.createIdentity();
positionTrans.transform( pxVec );
_pRigidBody->setGlobalPose( positionTrans );
Thanks in advanced
Check if the pose is valid:
positionTrans.isValid();
If it is valid, i think the problem must be somewhere else.
maxhap
August 6, 2015, 11:03am
3
Thanks for the reply, isValid() always returns false, even when I try simple values
pxVec.x = 0.0f;
pxVec.y = 0.0f;
pxVec.z = 0.0f;
if ( positionTrans.isValid() )
The values in the Transform matrix are all 107374176 no matter the values I use in the vector.
try this:
physx::PxTransform positionTrans(physx::PxMat44(physx::PxMat33(1.0), physx::PxVec3(pxVec)));
maxhap
August 6, 2015, 12:41pm
5
I’m not sure why the above didn’t work but after looking at the documentation again I found PxTransform can take a position vector in the constructor, the below code correctly sets the position.
physx::PxTransform positionTrans( pxVec );
