Hello!
It’s my first topic on this forum. Nvidia PhysX is really great library for game development.
I have some knowledge in DirectX 10. I want to use PhysX with DirectX 10. But when I try to compile the code, I get a lot of linker errors.
I have downloaded the latest PhysX sdk for windows. I have read the documentation and examples, but everything is in Open GL.
Well, I can compile examples, create a new PhysX project, initialize and shut down the PhysX. But when I add the DirectX 10, I get a lot of linker errors.
I’m not sure, but the problem is CRT conflict between PhysX and DirectX sdks.
In latest PhysX online guide is written:
“Note
The static libraries we provide with the Windows binary distribution are linked against the Multi-Threaded static C Run-Time (CRT) libraries. This means that your application must also use the same CRT flavor. If you need to use a different CRT version, you must upgrade to our source license. The source distribution can simply be recompiled using different CRT settings.”
My direct X projects are linked against /MD. When I try to link them against /MT, linker errors again.
Does anybody know the solution? If recompiling is necessary, how is it done?
Thank you for you help.
P.S. It would be nice to post a tutorial about PhysX + DirectX, because there are a lot of people, who are interested in both SDKs.
