Hello
I use convexHull->saveToDesc() in PhysX 2.8 to retreive a triangle mesh (vertex buffer + index buffer) from a convex hull (stored as a vertex buffer only). In other words, I use PhysX to create triangle-based index buffers in order to display convex hulls in an editor.
How can I do the same in PhysX 3 please ?
Finally I think I can deal with polygon data of the convex hulls :
these polygons are convex so I can easily decompose them into triangles.
sry for the delay.
Did you solved your problem?
Hello
I think so but I can’t be sure, because I have another serious problem : cookConvexMesh() and cookTriangleMesh() (PhysX 3) are both crashing the application when I call them. However, I’ve checked the descriptions I give to them and they seems valid …
Hi
hm. Would you show us how you initalize PhysX and how you cook your mesh?
Its much easier for us when we see your code.
Just debug your code - maybe there is somewhere an invalid pointer.
Which version of PhysX do you use?
Against which libs are you linking? (RELEASE, DEBUG, CHECKED ?)
Hello
I use Physx 3.2.4 on Vista 32 bit
Here the initialization :
static PxDefaultErrorCallback errorCallback;
static PxDefaultAllocator allocatorCallback;
foundation=PxCreateFoundation(PX_PHYSICS_VERSION,allocatorCallback,errorCallback);
if (foundation==NULL) return;
profileZoneManager=&PxProfileZoneManager::createProfileZoneManager(foundation);
if(profileZoneManager==NULL) return;
#ifdef _DEBUG
physics=PxCreateBasePhysics(PX_PHYSICS_VERSION,*foundation,PxTolerancesScale(),true,profileZoneManager);
#else
physics=PxCreateBasePhysics(PX_PHYSICS_VERSION,*foundation,PxTolerancesScale(),false,profileZoneManager);
#endif
if (physics==NULL) return;
cooking=PxCreateCooking(PX_PHYSICS_VERSION,*foundation,PxCookingParams());
if (cooking==NULL) return;
if (!PxInitExtensions(*physics)) return;
PxSceneDesc sceneDesc(physics->getTolerancesScale());
sceneDesc.gravity=PxVec3(0.0f,-9.81f,0.0f);
cpuDispatcher=PxDefaultCpuDispatcherCreate(1);
if (cpuDispatcher==NULL) return;
sceneDesc.cpuDispatcher=cpuDispatcher;
sceneDesc.filterShader=PxDefaultSimulationFilterShader;
scene=physics->createScene(sceneDesc);
if (scene==NULL) return;
physics, cooking, scene are valid pointers after the initialization.
I use the cooking methods for triangle mesh and convex hull as it is described in the user guide.
I link with CHECKED libs in debug mode, RELEASE in release mode
The crash happens in both modes.
I hope it is just something I omitted in my PhysX initialization …
I’ve just noticed that __vfptr of physics, cooking, scene and cpuDispatcher are invalid ! (after the initialization)
Don’t worry, I called the destructor by accident, applying release at these objects … before cooking …
Thank you for your help
