It’s a device query for nvidia.
/opt/NVIDIA_GPU_Computing_SDK/C/bin/linux/release/deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
There are 4 devices supporting CUDA
Device 0: “Tesla S2050”
CUDA Driver Version: 3.20
CUDA Runtime Version: 3.20
CUDA Capability Major/Minor version number: 2.0
Total amount of global memory: 2817982464 bytes
Multiprocessors x Cores/MP = Cores: 14 (MP) x 32 (Cores/MP) = 448 (Cores)
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Clock rate: 1.15 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: No
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Concurrent kernel execution: Yes
Device has ECC support enabled: Yes
Device is using TCC driver mode: No
Device 1: “Tesla S2050”
Warp size: 32
Integrated: No
Device 2: “Tesla S2050”
Warp size: 32
Integrated: No
Device 3: “Tesla S2050”
Warp size: 32
Integrated: No
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 3.20, CUDA Runtime Version = 3.20, NumDevs = 4, Device = Tesla S2050, Device = Tesla S2050
PASSED
Press to Quit…
And code is
#include <stdio.h>
#include <cuda.h>
#include <math.h>
#define NUM_THREAD 1024
global void cal_pi(float sum, long long nbin, float step, long long nthreads, long long nblocks) {
long long i;
float x;
long long idx = blockIdx.xblockDim.x+threadIdx.x;
for (i=idx; i< nbin; i+=nthreads*nblocks) {
x = (i+0.5)*step;
sum[idx] = sum[idx]+4.0/(1.+x*x);
int main(void) {
long long tid;
float pi = 0;
long long num_steps = 10000000;
dim3 numBlocks(NUM_THREAD*NUM_THREAD*(int)sqrt(NUM_THREAD),1,1);
dim3 threadsPerBlock(NUM_THREAD,1,1);
float *sumHost, *sumDev;
float step = 1./(float)num_steps;
long long size = NUM_THREAD*NUM_THREAD*NUM_THREAD*(int)sqrt(NUM_THREAD)*sizeof(float);
// clock_t before, after;
sumHost = (float *)malloc(size);
cudaMalloc((void **)&sumDev, size);
// Initialize array in device to 0
cudaMemset(sumDev, 0, size);
// before = clock();
// Do calculation on device
printf("Before Compute \n\n");
cal_pi <<<numBlocks, threadsPerBlock>>> (sumDev, (int)num_steps, step, NUM_THREAD, NUM_THREAD*NUM_THREAD*(int)sqrt(NUM_THREAD) ); // call CUDA kernel
printf("After Compute \n\n");
// Retrieve result from device and store it in host array
cudaMemcpy(sumHost, sumDev, size, cudaMemcpyDeviceToHost);
printf("After Copy \n\n");
for(tid=0; tid<NUM_THREAD*NUM_THREAD*NUM_THREAD*(int)sqrt(NUM_THREAD); tid++){
pi = pi+sumHost[tid];
printf("The value of PI is %d\n",tid);
pi = pi*step;
//after = clock();
printf("The value of PI is %15.12f\n",pi);
//printf("The time to calculate PI was %f seconds\n",((double)(after - before)/1000.0));
free(sumHost);
cudaFree(sumDev);
return 0;
my problem is pi’s value is 0.00000 why noy 3.1415…
please tell me or edit my code please
thank you
