Hi Nvidia team.
I was checking the 3.3V Tolerance Enable, but I had two questions.
- If I set a pin as 3.3V Tolerance Enable as INPUT, it means that I can receive 3.3 V signals?
- If I set a pin as 3.3V Tolerance Enable as OUTPUT, it means that I will output 3.3 V signals?
3.3v tolerance means the pin can bear 3.3v input.
To set the output voltage of a pin to 3.3V, what column do I need to change?
The IO Block Voltage
column?
1.8v pin can not output 3.3v level.
system
Closed
8
