I have Sierra USB modem connected to TX1 devkit with R24.2.1. As recommendation from vendor i have installed Gobinet and Gobiserial drivers which created ttyUSBx and qcqmi0 nodes. Also GobiAPI(QMI) provided from Vendor able to talk with modem. Once i enabled the data session and try using ping, am not getting any reply messages. Same when I install drivers and APIs in my local ubuntu PC it works fine.
Following are the host setup requirement:
The Linux distribution may have in built drivers and applications that can interfere with SDK process’s
execution. The below Qualcomm drivers, if present, need to be black listed.
- qcserial
- qmi_wwan
Please black list them as below (example is for Ubuntu). Add the 2 entries to the
“/etc/modprobe.d/blacklist-modem.conf” file and restart the host
blacklist qcserial
blacklist qmi_wwan
“Modem Manager” is another application that can interfere with the SDK’s operation. Please remove it
and restart the host. Below example is for an Ubuntu PC:
#sudo apt-get remove modemmanager
#sudo killall -9 modemmanager
#sudo reboot
In wireshark, am able to see ICMP reply from 8.8.8.8 but somehow it is discarding in TX1. Also i have checked the packets via tcpdump, and packets am seeing as below when i give ping 8.8.8.8:
14:53:10.193672 IP 10.81.83.241 > 8.8.8.8: ICMP echo request, id 2062, seq 14, length 64
14:53:10.321686 IP 8.8.8.8 > 10.81.83.241: ICMP echo reply, id 2062, seq 14, length 64
14:53:11.194101 IP 10.81.83.241 > 8.8.8.8: ICMP echo request, id 2062, seq 15, length 64
14:53:11.376100 IP 8.8.8.8 > 10.81.83.241: ICMP echo reply, id 2062, seq 15, length 64
14:53:12.194039 IP 10.81.83.241 > 8.8.8.8: ICMP echo request, id 2062, seq 16, length 64
route command:
default 10.81.83.242 0.0.0.0 UG 100 0 0 eth0
10.81.83.240 * 255.255.255.252 U 100 0 0 eth0
link-local * 255.255.0.0 U 1000 0 0 usb0
192.168.2.0 * 255.255.255.0 U 100 0 0 usb0
192.168.100.0 * 255.255.252.0 U 0 0 0 wlan0
NOTE: Attached file is the wireshark pcap file need to rename as capture.pcap for viewing in wireshark.
Any suggestion on this would help me to resolve this issue.
Thanks in Advance.
capture.txt (63 KB)
