So I saw this post (Pinmux update step by step) questioning how to use the pinmux excel spreadsheet. It is a bit outdated, so figured I would start another one since I am having problems.
I am using Jetpack 5.0.2 (and then 5.1 soon as it was just released a few days ago) on a Xavier NX devkit w/ eMMC.
I am disabling pins 160 and 162 (PEX_CLK5) in the spreadsheet and need to confirm they are ‘not assigned’ after flash. How do confirm after flashing and the devkit boots?
Here is my procedure:
I can compile the pinmux changes from the spreadsheet, convert the .dtsi files to .cfg files and place them in the /Linux_for_tegra/bootloader/t186ref/BCT directory.
I have not changed anything in the /rootfs/boot/extlinux/extlinux.conf file (as some mentioned to change, but I have not).
I can flash the devkit using CLI (sudo ./flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1)
Is that all that needs to be done? Do I need to recompile the kernel, dtb files, or anything else as some have suggested from forum posts (I have not done any of those steps)?
If anyone can provide a step-by-step procedure for this activity, that would be great!
Thanks in advance.
P.S. I’ve also used parts of this blog post, but it seems outdated as well and caused my devkit not to boot.
When you run flash.sh, you shall see lots of logs got print on your terminal. Search if your cfg file name is printed in those logs.
It is not easy to read the register status as each pin has its own register address. devmem tool (upstream ubuntu tool) can read the register. But you need to check the TRM (technical reference manual) of Xavier SoC to find out which address to check.
