We have contracted out a new carrier board for a tx2i. The contractor has provided an updated pinmux xls file. I took those dsti files and did this:
cd /data/Linux_for_Tegra/kernel/pinmux/t186
python pinmux-dts2cfg.py --pinmux addr_info.txt gpio_addr_info.txt por_val.txt tegra18x-jetson-tx2i-tx2-4gb-template-pinmux.dtsi tegra18x-jetson-tx2i-tx2-4gb-template-gpio-default.dtsi 1.0 > ../../../bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3489-1000-a00.cfg
python pinmux-dts2cfg.py --pad pad_info.txt tegra18x-jetson-tx2-config-template-padvoltage-default.dtsi 1.0 > ../../../bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3489-1000-a00.cfg
I then flash the board
sudo ./flash.sh jetson-tx2i.conf mmcblk0p1
The cfg files are attached.
tegra186-mb1-bct-pad-quill-p3489-1000-c03.cfg (499 Bytes)
tegra186-mb1-bct-pinmux-quill-p3489-1000-a00.cfg (24.8 KB)
Questions:
Do we have to rebuild the kernel also or is the cfg file placement and flash sufficient?
It looks like the AUDIO_HW and DMIC_HV are not being updated to power from the 3.3V regulator. if you read the dtd and dts files, the rails are sill powered by the 1.8V regulator.
Thanks,
John
Do I also need to update a dtsi file?
Hello, I am still struggling with this. I have simplified my test case to test on my P3310 tx2 devkit.
I only do the following in the spreadsheet:
set AUDIO_HV to 3.3V
set DMIC_HV to 3.3V
change GPIO3_PI.04 to be an output
I generate the dsti files and the cfg files.
I process them like this:
cd ${DIR}/kernel/pinmux/t186
python pinmux-dts2cfg.py --pinmux addr_info.txt gpio_addr_info.txt por_val.txt tegra18x-jetson-tx2-config-1-pinmux.dtsi tegra18x-jetson-tx2-config-1-gpio-default.dtsi 1.0 > …/…/…/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
python pinmux-dts2cfg.py --pad pad_info.txt tegra18x-jetson-tx2-config-1-padvoltage-default.dtsi 1.0 > …/…/…/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
I rebuild the kernel and flash it.
I then look at DMIC_HV Pin GPIO3_PI.04 (which should be gpio388 ( or pin 37 on J21).
I Measure J21:Pin37 = 1.8V
What is the next step? It feels like the cfg file is not taking effect.
Thanks,
John
kayccc
February 21, 2023, 3:36am
5
Is this still an issue to support? Any result can be shared? Thanks
Hello, I never made progress on this. Apparently our contractor asked independently and Nvidia said it wasn’t possible.
John
