Using L4T 32.6.1 on a TX2 Devkit, I’m unable to export GPIO 303 (which I believe is appropriate for GPIO3_PAA.07 - B25 - GPIO6_TOUCH_INT).
“write error: Device or resource busy”
With cat /sys/kernel/debug/tegra_pinctrl_reg | grep paa, I don’t see gpio3_paa7 configured.
Can you assist at all with what modifications might be needed for tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg in order to get this to work?
Apologies if I’m lacking any details, will happily add them. Any help appreciated!
According to the TX2 datasheet pin B25 (GPIO 303) has an output voltage of 1.8V. I would like to ask if it is possible to change the voltage of this pin to 3.3V? If yes, could you help with how the voltage can be changed?
