Hello, I have a Jetson Orin Nano Devkit. I edited the pinmux configuration to make board pins 12, 18, 22, 23, 26, 33, 19, 32 bidirectional. When I set the pins to High, I measured 1.6 volt in between ground of the board and High output.
My question is shouldn’t this be equal to 3.3 volt instead? Before using a multimeter I used leds to test. By doing so did I change the logic level ? So is there a fail safe feature to reduce output power?
Finally, is there a function to activate TXB0108 level shifter in pinmux table?
I am using Jetpack 6.2 the device is Jetson Orin Nano Super devkit. Yes, I mean 40-pins expansion headers.
I will try the scope as well but for comparison the Jetson Orin Nano devkit with Jetpack 5.1.2.
I couldn’t use the scope yet. I am using Jetson.GPIO module.
Here is what I did:
import Jetson.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setup(10, GPIO.OUT)
GPIO.out(10, True)
Here is how I configured that pin as biderectional. I just noticed 3.3 volt tolerance parameter. I am setting it to Enable and reflashing the device now.
Update:
I from the 40-pins extansion board the number 36 (I found out that it’s GPIO3_PR.05) doesn’t have that function. When I measure the output voltage of pin 36, it’s equal to 1.5 bolt with multimiter. Probably, it will be equal to 1.8 with scope:
I would suggest you using scope to check if it is stable 1.6volts or a wave due to SFIO bit enabled.
Yes, the PIN36 from 40-pins expansion header is PR.05 as following.
Could you try to configure it as GPIO3_PR.05/Bidirectional/Drive 1 in pinmux spreadsheet and measure its signal after boot up?
Thanks for the suggestions. It’s default output is 3.3 volt, indeed. However it’s fluctuating and if I connect a load like LED,the output becomes 1.8 volt (or 1.6 volt depends on the measurement method).
