Hello.
I want to clarify the rules for editing a table.
If I don’t use interfaces then I have to set the fields Customer Usage and Pin Direction to unused_*** and Not Assigned?
In the table I see that for some unused pins in devkit, fields Customer Usage and Pin Direction are set however.
Some pins have comments - unused (3.3V Tolerance Enabled to protect pad) . I should not change the properties of these pins?
Thank you.
I’m at the stage of developing my board. I bought a devkit and it will be delivered soon. Can I install Orin from the devkit on my board? After all, it will be programmed for a different board configuration.
