Hi, I’d like to modify my tx2nx pinmux without using excel to generate the cfg, I don’t have a computer with windows installed
Linux works for this if you use libreoffice
(free, and often installed by default). Just make sure you enable macros.
That aside, you can reverse compile an existing device tree if you know the correct one, edit the device tree source, and then recompile it back to binary format. The application “dtc
” (installed via “sudo apt-get install device-tree-compiler
”) does this. Example if your binary is “tree.dtb
dtc -I dtb -O dts -o source.dts tree.dtb
# Edit source.dts in an editor, then back to binary format:
dtc -I dts -O dtb -o new_tree.dtb source.dts
