I still hope to find out what causes this problem. As some people suggest, I break the cudaMallocHost() call into two calls: posix_memalign() and cudaHostRegister().
Here’s my new testing program:
#include <iostream>
#include <assert.h>
#include <cuda.h>
#include <cuda_runtime.h>
using namespace std;
int main() {
size_t count = 0;
size_t size = 64 * 1024 * 1024 * sizeof(float);
while (true) {
void *ptr;
while (posix_memalign(&ptr, 4096, size) != 0) {
cout << "posix_memalign failed at " << count * 256 << " MB" << endl;
cout << "ptr = " << ptr << endl;
while (cudaHostRegister(ptr, size, 0) != cudaSuccess) {
cout << "cudaHostRegister failed at " << count * 256 << " MB" << endl;
count++;
cout << "Allocated " << count * 256 << " MB" << endl;
The program always fails at the cudaHostRegister() call when the allocated memory approaches 4 GB. I’m using Ubuntu 14.04 with CUDA 7.5.
Do you have any ideas how the cudaHostRegister() is implemented? I really hope I can write a simple program to emulate what cudaHostRegister(), but without using CUDA APIs, so that I can find out whether it’s a Ubuntu issue or CUDA issue.
Thank you!
Cui
