I’m trying to enable pins F20 and F21 (PEX_CLK3_P and PEX_CLK3_N) in the Orin Pinmux Config Template 1.5, but the spreadsheet will not allow any other options other than unused
It is unused. Only the lane mapping in DG is supported.
Do you mean it’s unused on the development kit? Because we have a custom board we’d like to use it on.
This was possible with Xavier, and I thought Orin was pin-compatible
It’s unused on all Orin design, as you can see in Orin design guide.
