Pip install fer > "No module named skbuild"
I am trying to use the FER (Facial Emotion Recognition) python module on my Xavier. pip install fer tries to install opencv-contrib-python which fails on the skbuild error. Things I have tried to far:
  • Build jetson-inference from source
Error still exists. Thanks in advance.
Progress
pip3 install --upgrade pip
followed by
pip3 install opencv-contrib-python
Completed without errors
Next issue: No module named tensorflow
Trying:
sudo pip3 install --pre --extra-index-url Index of /compute/redist/jp/v42 tensorflow-gpu
Which JetPack version do you use?
We recommend installing our latest JetPack 4.6 and the corresponding command is:
sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v46 tensorflow
You can find the detailed instructions in this document.
I will try this. Thank you.
Yay. So far, so good.
from fer import Video
2021-10-04 09:39:59.670542: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcudart.so.10.2
Good to know this.
Thanks for the feedback.
