I’m having trouble with pip libraries and the new USD Composer that replaced Create. In my extension, I’m using some third-party libraries from pip, which I’ve been importing through the extension.toml configuration e.g.
This has been working fine in Code, View, and Create, but fails in the USD Composer app that recently replaced Create with an error like ModuleNotFoundError: No module named 'pandas' .
I’m having the same issue with “pandas” and “opencv-python”; once again only on the new USD Composer app as it used to work just fine on 2022.3.* versions.
I found an issue that on the first installation our pipapi extension tries to update pip to an older version, which we probably didn’t update since the python update.
There is a custom hack you can do, in that file: omni.kit.pipapi\omni\kit\pipapi\pipapi.py
change line _attempted_to_upgrade_pip = False to _attempted_to_upgrade_pip = True
then you need to clean app data (pip installation dir specifically), either manually remove: %localappdata%\ov\data\Kit\USD.Composer\2023.1\pip3-envs
or restart an app with --clear-data CLI flag
Thanks @anovoselov !
Is this the omni.kit.pipapi\omni\kit\pipapi\pipapi.py file that is in the USDComposer extscache? (i.e. C:\Users\SFOEBB\AppData\Local\ov\pkg\create-2023.1.0\extscache\omni.kit.pipapi-0.0.0+ed961c5c\omni\kit\pipapi\pipapi.py)
