@anovoselov
I checked with 2022 and 2023 versions of Create and still facing the same issue. I tried with installing the LangChain in external as well as in internal directory and provided those as explicit import paths but facing the same issue.
I am able to import langchain on command line with the provided versions of python in omniverse, but its not working with script editor or as an extension.
import sys
# appending a path Create 2023
#sys.path.append(r'C:/Users/pranav.buradkar/AppData/Local/ov/data/Kit/USD.Composer/2023.1/pip3-envs/default')
#sys.path.append(r'C:/Users/pranav.buradkar/AppData/Local/ov/data/Kit/USD.Composer/2023.1/pip3-envs/default/langchain')
# appending a path Create 2022
# sys.path.append(r'C:/Users/pranav.buradkar/AppData/Local/ov/data/Kit/Create.Next/2022.3/pip3-envs/default')
# sys.path.append(r'C:/Users/pranav.buradkar/AppData/Local/ov/data/Kit/Create.Next/2022.3/pip3-envs/default/langchain')
print (f"path ---> {sys.path}")
import omni.ext
import omni.ui as ui
#import openai
from langchain.llms import AzureOpenAI
#from langchain.llms.openai import AzureOpenAI, OpenAI
LOG -
[35.172s] RTX ready
[141.846s] [ext: omni.kit.registry.nucleus-0.0.0] startup
[154.293s] [ext: omni.hello.world-1.0.0] startup
2023-07-18 06:27:52 [154,209ms] [Warning] [omni.kit.pipapi.pipapi] extension omni.hello.world-1.0.0 has a [python.pipapi] entry, but use_online_index=true is not set. It doesn't do anything and can be removed.
path ---> ['c:\\users\\pranav.buradkar\\appdata\\local\\ov\\pkg\\create-2023.1.1\\kit\\kernel\\plugins\\python310.zip', 'c:\\users\\pranav.buradkar\\appdata\\local\\ov\\pkg\\create-2023.1.1\\kit\\python\\DLLs', 'c:\\users\\pranav.buradkar\\appdata\\local\\ov\\pkg\\create-2023.1.1\\kit\\python\\lib', 'C:\\Users\\pranav.buradkar\\AppData\\Local\\ov\\pkg\\create-2023.1.1\\kit', 'c:\\users\\pranav.buradkar\\appdata\\local\\ov\\pkg\\create-2023.1.1\\kit\\python', 'c:\\users\\pranav.buradkar\\appdata\\local\\ov\\pkg\\create-2023.1.1\\kit\\python\\lib\\site-packages', '.', 'c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/kit/kernel/py', 'c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/kit/plugins/bindings-python', 'c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/kit/bindings-python']
2023-07-18 06:27:52 [154,247ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.hello.world. Error: No module named 'langchain'. Traceback:
File "c:\users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/kit/kernel/py\omni\ext\_impl\custom_importer.py", line 76, in import_module
return importlib.import_module(name)
File "c:\users\pranav.buradkar\appdata\local\ov\pkg\create-2023.1.1\kit\python\lib\importlib\__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "c:/projects/omniverse/kit-extension-template-main_test_langchain/exts/omni.hello.world/omni/hello/world/__init__.py", line 1, in <module>
from .extension import *
File "c:/projects/omniverse/kit-extension-template-main_test_langchain/exts/omni.hello.world/omni/hello/world/extension.py", line 18, in <module>
ModuleNotFoundError: No module named 'langchain'
2023-07-18 06:27:52 [154,249ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.hello.world' in 'c:\projects\omniverse\kit-extension-template-main_test_langchain\exts\omni.hello.world' failed to load.
At:
c:\users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/kit/kernel/py\omni\ext\_impl\_internal.py(212): startup
c:\users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/kit/kernel/py\omni\ext\_impl\_internal.py(323): startup_extension
PythonExtension.cpp::startup()(2): <module>
c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/extscache/omni.kit.window.extensions-1.1.9+ed961c5c/omni/kit/window/extensions/ext_commands.py(29): do
c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/extscache/omni.kit.commands-1.4.6+ed961c5c.wx64.r.cp310/omni/kit/undo/undo.py(80): execute
c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/extscache/omni.kit.commands-1.4.6+ed961c5c.wx64.r.cp310/omni/kit/commands/command.py(463): execute
c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/extscache/omni.kit.window.extensions-1.1.9+ed961c5c/omni/kit/window/extensions/common.py(288): toggle_extension
c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/extscache/omni.kit.window.extensions-1.1.9+ed961c5c/omni/kit/window/extensions/ext_components.py(89): toggle
2023-07-18 06:27:52 [154,249ms] [Error] [omni.ext.plugin] [ext: omni.hello.world-1.0.0] Failed to startup python extension.
EDIT-
I have changed the sys.append path to Windows style, I think its able to find the module but still cant locate the langchain.llms
File "c:/projects/omniverse/kit-extension-template-main_test_langchain/exts/omni.hello.world/omni/hello/world/extension.py", line 20, in <module>
File "c:/projects/omniverse/kit-extension-template-main_test_langchain/exts/omni.hello.world/omni/hello/world/extension.py", line 21, in <module>
Full Log -
[435.338s] [ext: omni.hello.world-1.0.0] shutdown
[435.368s] [ext: omni.hello.world-1.0.0] startup
2023-07-18 07:03:11 [435,300ms] [Warning] [omni.kit.pipapi.pipapi] extension omni.hello.world-1.0.0 has a [python.pipapi] entry, but use_online_index=true is not set. It doesn't do anything and can be removed.
path ---> ['c:\\users\\pranav.buradkar\\appdata\\local\\ov\\pkg\\create-2023.1.1\\kit\\kernel\\plugins\\python310.zip', 'c:\\users\\pranav.buradkar\\appdata\\local\\ov\\pkg\\create-2023.1.1\\kit\\python\\DLLs', 'c:\\users\\pranav.buradkar\\appdata\\local\\ov\\pkg\\create-2023.1.1\\kit\\python\\lib', 'C:\\Users\\pranav.buradkar\\AppData\\Local\\ov\\pkg\\create-2023.1.1\\kit', 'c:\\users\\pranav.buradkar\\appdata\\local\\ov\\pkg\\create-2023.1.1\\kit\\python', 'c:\\users\\pranav.buradkar\\appdata\\local\\ov\\pkg\\create-2023.1.1\\kit\\python\\lib\\site-packages', '.', 'c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/kit/kernel/py', 'c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/kit/plugins/bindings-python', 'c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/kit/bindings-python', 'C:\\Users\\pranav.buradkar\\AppData\\Local\\ov\\data\\Kit\\USD.Composer\\2023.1\\pip3-envs\\default', 'C:\\Users\\pranav.buradkar\\AppData\\Local\\ov\\data\\Kit\\USD.Composer\\2023.1\\pip3-envs\\default\\langchain']
2023-07-18 07:03:11 [435,311ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.hello.world. Error: cannot import name 'NotRequired' from 'typing_extensions' (c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/extscache/omni.services.pip_archive-0.6.0+wx64/pip_prebundle/typing_extensions.py). Traceback:
File "C:\Users\pranav.buradkar\AppData\Local\ov\data\Kit\USD.Composer\2023.1\pip3-envs\default\langchain\__init__.py", line 6, in <module>
from langchain.agents import MRKLChain, ReActChain, SelfAskWithSearchChain
File "C:\Users\pranav.buradkar\AppData\Local\ov\data\Kit\USD.Composer\2023.1\pip3-envs\default\langchain\agents\__init__.py", line 2, in <module>
from langchain.agents.agent import (
File "C:\Users\pranav.buradkar\AppData\Local\ov\data\Kit\USD.Composer\2023.1\pip3-envs\default\langchain\agents\agent.py", line 40, in <module>
from langchain.utilities.asyncio import asyncio_timeout
File "C:\Users\pranav.buradkar\AppData\Local\ov\data\Kit\USD.Composer\2023.1\pip3-envs\default\langchain\utilities\__init__.py", line 3, in <module>
from langchain.utilities.apify import ApifyWrapper
File "C:\Users\pranav.buradkar\AppData\Local\ov\data\Kit\USD.Composer\2023.1\pip3-envs\default\langchain\utilities\apify.py", line 5, in <module>
from langchain.document_loaders import ApifyDatasetLoader
File "C:\Users\pranav.buradkar\AppData\Local\ov\data\Kit\USD.Composer\2023.1\pip3-envs\default\langchain\document_loaders\__init__.py", line 45, in <module>
from langchain.document_loaders.embaas import EmbaasBlobLoader, EmbaasLoader
File "C:\Users\pranav.buradkar\AppData\Local\ov\data\Kit\USD.Composer\2023.1\pip3-envs\default\langchain\document_loaders\embaas.py", line 7, in <module>
from typing_extensions import NotRequired, TypedDict
ImportError: cannot import name 'NotRequired' from 'typing_extensions' (c:/users/pranav.buradkar/appdata/local/ov/pkg/create-2023.1.1/extscache/omni.services.pip_archive-0.6.0+wx64/pip_prebundle/typing_extensions.py)
2023-07-18 07:03:11 [435,312ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.hello.world' in 'c:\projects\omniverse\kit-extension-template-main_test_langchain\exts\omni.hello.world' failed to load.
At:
2023-07-18 07:03:11 [435,313ms] [Error] [omni.ext.plugin] [ext: omni.hello.world-1.0.0] Failed to startup python extension.
