Hi @rasterizer , Yes I can reproduce bug on nVidia GT 1650. Also, during waiting some time I will have crash
Please update your simple project for using multiple gpu, gpu index can be set using command line arguments
#pragma comment(lib, "vulkan-1.lib")
#include <cstddef>
#include <cstdint>
#include <iostream>
#include <fstream>
#include <vector>
#define VK_USE_PLATFORM_WIN32_KHR
#include <vulkan/vulkan.h>
#define CHECK(x) if (!(x)) { std::cout << "Check failed at line " << __LINE__ << ".\r\n"; std::cin.get(); exit(1); }
#define VULKAN_CHECK(x) CHECK((x) >= 0)
VKAPI_ATTR VkBool32 VKAPI_CALL DebugReport(VkDebugReportFlagsEXT flags, VkDebugReportObjectTypeEXT objType, std::uint64_t obj, std::size_t location, std::int32_t code, const char* layerPrefix, const char* msg, void* userData)
std::cout << msg << "\r\n";
return VK_FALSE;
VkResult CreateDebugReportCallbackEXT(VkInstance instance, const VkDebugReportCallbackCreateInfoEXT* pCreateInfo, const VkAllocationCallbacks* pAllocator, VkDebugReportCallbackEXT* pCallback)
auto func = reinterpret_cast<PFN_vkCreateDebugReportCallbackEXT>(vkGetInstanceProcAddr(instance, "vkCreateDebugReportCallbackEXT"));
if (!func)
return VK_ERROR_EXTENSION_NOT_PRESENT;
return func(instance, pCreateInfo, pAllocator, pCallback);
int main(int argc, char* argv[])
std::cout << "Initializing...\r\n";
const char* extensions[] = { VK_EXT_DEBUG_REPORT_EXTENSION_NAME };
const char* layers[] = { "VK_LAYER_KHRONOS_validation" };
VkDebugReportFlagsEXT debugReportFlags = VK_DEBUG_REPORT_ERROR_BIT_EXT | VK_DEBUG_REPORT_WARNING_BIT_EXT | VK_DEBUG_REPORT_PERFORMANCE_WARNING_BIT_EXT;
// Instance
VkInstanceCreateInfo instanceInfo = {};
instanceInfo.sType = VK_STRUCTURE_TYPE_INSTANCE_CREATE_INFO;
instanceInfo.pApplicationInfo = nullptr;
instanceInfo.enabledExtensionCount = static_cast<std::uint32_t>(sizeof(extensions) / sizeof(extensions[0]));
instanceInfo.ppEnabledExtensionNames = extensions;
instanceInfo.enabledLayerCount = static_cast<std::uint32_t>(sizeof(layers) / sizeof(layers[0]));
instanceInfo.ppEnabledLayerNames = layers;
VkInstance instance;
VULKAN_CHECK(vkCreateInstance(&instanceInfo, nullptr, &instance));
// Debug report callback
VkDebugReportCallbackCreateInfoEXT debugCallbackInfo = {};
debugCallbackInfo.sType = VK_STRUCTURE_TYPE_DEBUG_REPORT_CALLBACK_CREATE_INFO_EXT;
debugCallbackInfo.flags = debugReportFlags;
debugCallbackInfo.pfnCallback = DebugReport;
VkDebugReportCallbackEXT debugReportCallback;
VULKAN_CHECK(CreateDebugReportCallbackEXT(instance, &debugCallbackInfo, nullptr, &debugReportCallback));
// Physical device
std::uint32_t physicalDeviceCount = 0;
VkPhysicalDevice physicalDevices[32];
//VULKAN_CHECK(vkEnumeratePhysicalDevices(instance, &physicalDeviceCount, &physicalDevice));
VULKAN_CHECK(vkEnumeratePhysicalDevices(instance, &physicalDeviceCount, nullptr));
VULKAN_CHECK(vkEnumeratePhysicalDevices(instance, &physicalDeviceCount, physicalDevices));
// Queue
std::uint32_t computeQueueFamilyIndex = -1;
std::uint32_t queueFamilyCount = 0;
uint32_t index = 0;
if (argc > 1) {
index = atoi(argv[1]);
if (index > physicalDeviceCount) {
index = 0;
VkPhysicalDevice physicalDevice = physicalDevices[index];
vkGetPhysicalDeviceQueueFamilyProperties(physicalDevices[index], &queueFamilyCount, nullptr);
std::vector<VkQueueFamilyProperties> queueFamilies(queueFamilyCount);
vkGetPhysicalDeviceQueueFamilyProperties(physicalDevice, &queueFamilyCount, queueFamilies.data());
for (std::uint32_t queueFamilyIndex = 0; queueFamilyIndex < queueFamilyCount; ++queueFamilyIndex)
VkQueueFamilyProperties& queueFamily = queueFamilies[queueFamilyIndex];
if (queueFamily.queueCount == 0)
continue;
if (!(queueFamily.queueFlags & VK_QUEUE_COMPUTE_BIT))
continue;
computeQueueFamilyIndex = queueFamilyIndex;
break;
CHECK(computeQueueFamilyIndex != -1);
// Device
float computeQueuePriority = 1.0f;
VkDeviceQueueCreateInfo queueInfo = {};
queueInfo.sType = VK_STRUCTURE_TYPE_DEVICE_QUEUE_CREATE_INFO;
queueInfo.queueFamilyIndex = computeQueueFamilyIndex;
queueInfo.queueCount = 1;
queueInfo.pQueuePriorities = &computeQueuePriority;
VkDeviceCreateInfo deviceInfo = {};
deviceInfo.sType = VK_STRUCTURE_TYPE_DEVICE_CREATE_INFO;
deviceInfo.pQueueCreateInfos = &queueInfo;
deviceInfo.queueCreateInfoCount = 1;
deviceInfo.pEnabledFeatures = nullptr;
deviceInfo.enabledExtensionCount = 0;
deviceInfo.ppEnabledExtensionNames = nullptr;
VkDevice device;
VULKAN_CHECK(vkCreateDevice(physicalDevice, &deviceInfo, nullptr, &device));
// Queue handle
VkQueue computeQueue;
vkGetDeviceQueue(device, computeQueueFamilyIndex, 0, &computeQueue);
// Shader module
std::vector<std::uint32_t> shaderCode;
std::ifstream shaderCodeStream("Shader.spv", std::ios::binary);
CHECK(shaderCodeStream);
for (std::uint32_t i; !shaderCodeStream.read(reinterpret_cast<char*>(&i), 4).eof(); shaderCode.push_back(i));
VkShaderModuleCreateInfo shaderModuleInfo = {};
shaderModuleInfo.sType = VK_STRUCTURE_TYPE_SHADER_MODULE_CREATE_INFO;
shaderModuleInfo.codeSize = shaderCode.size() * 4;
shaderModuleInfo.pCode = shaderCode.data();
VkShaderModule shaderModule;
VULKAN_CHECK(vkCreateShaderModule(device, &shaderModuleInfo, nullptr, &shaderModule));
// Descriptor set layout
VkDescriptorSetLayoutBinding descriptorSetLayoutBinding = {};
descriptorSetLayoutBinding.binding = 0;
descriptorSetLayoutBinding.descriptorCount = 1;
descriptorSetLayoutBinding.descriptorType = VK_DESCRIPTOR_TYPE_STORAGE_BUFFER;
descriptorSetLayoutBinding.stageFlags = VK_SHADER_STAGE_COMPUTE_BIT;
VkDescriptorSetLayoutCreateInfo descriptorSetLayoutInfo = {};
descriptorSetLayoutInfo.sType = VK_STRUCTURE_TYPE_DESCRIPTOR_SET_LAYOUT_CREATE_INFO;
descriptorSetLayoutInfo.bindingCount = 1;
descriptorSetLayoutInfo.pBindings = &descriptorSetLayoutBinding;
VkDescriptorSetLayout descriptorSetLayout;
VULKAN_CHECK(vkCreateDescriptorSetLayout(device, &descriptorSetLayoutInfo, nullptr, &descriptorSetLayout));
// Pipeline layout
VkPipelineLayoutCreateInfo pipelineLayoutInfo = {};
pipelineLayoutInfo.sType = VK_STRUCTURE_TYPE_PIPELINE_LAYOUT_CREATE_INFO;
pipelineLayoutInfo.setLayoutCount = 1;
pipelineLayoutInfo.pSetLayouts = &descriptorSetLayout;
pipelineLayoutInfo.pushConstantRangeCount = 0;
pipelineLayoutInfo.pPushConstantRanges = nullptr;
VkPipelineLayout pipelineLayout;
VULKAN_CHECK(vkCreatePipelineLayout(device, &pipelineLayoutInfo, nullptr, &pipelineLayout));
// Pipeline
VkPipelineShaderStageCreateInfo shaderStage = {};
shaderStage.sType = VK_STRUCTURE_TYPE_PIPELINE_SHADER_STAGE_CREATE_INFO;
shaderStage.stage = VK_SHADER_STAGE_COMPUTE_BIT;
shaderStage.module = shaderModule;
shaderStage.pName = "main";
VkComputePipelineCreateInfo pipelineInfo = {};
pipelineInfo.sType = VK_STRUCTURE_TYPE_COMPUTE_PIPELINE_CREATE_INFO;
pipelineInfo.stage = shaderStage;
pipelineInfo.layout = pipelineLayout;
VkPipeline pipeline;
std::cout << "Creating pipeline...\r\n";
VULKAN_CHECK(vkCreateComputePipelines(device, VK_NULL_HANDLE, 1, &pipelineInfo, nullptr, &pipeline));
std::cout << "Done.\r\n";
std::cin.get();
return 0;
AMD RX 560 - no problem.
