Pipeline fails to change states
• Hardware Platform: GPU
• DeepStream Version: 5.0.0
• TensorRT Version: 7.0.0.11
• NVIDIA GPU Driver Version (valid for GPU only): 460.32.03
Hi, I’m having this pipeline:
filesrc → qtdemux → h264parse → nvv4l2decoder → nvstreammux → nvinfer (pgie) → queue → nvinfer (sgie) → queue → nvvideoconvert → queue → osd ->nvvideoconvert → x264enc → filesink
with pgie config:
[property]
gpu-id=0
net-scale-factor=0.0078431372
offsets=119.8561;110.8077;104.1462
onnx-file=/opt/models/detection.onnx
labelfile-path=labels.txt
infer-dims=3;320;320
batch-size=1
# 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
num-detected-classes=2
interval=0
gie-unique-id=1
parse-bbox-func-name=NvDsInferParseCustomSSD
custom-lib-path=nvdsinfer_primary_parser/libnvdsinfer_primary_parser.so
#scaling-filter=0
#scaling-compute-hw=0
[class-attrs-all]
pre-cluster-threshold=0.1
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
# Per class configuration
#[class-attrs-2]
#threshold=0.6
#roi-top-offset=20
#roi-bottom-offset=10
#detected-min-w=40
#detected-min-h=40
#detected-max-w=400
#detected-max-h=800
and sgie conf:
[property]
gpu-id=0
net-scale-factor=1
onnx-file=/opt/models/lmd192.onnx
batch-size=1
# Integer 1=Primary 2=Secondary
process-mode=2
gie-unique-id=2
operate-on-gie-id=1
#nw mode 0: FP32, 1: INT8, 2: FP16
network-mode=0
# Integer 0: OpenCV groupRectangles() 1: DBSCAN 2: Non Maximum Suppression 3: DBSCAN + NMS Hybrid 4:No clustering
cluster-mode=2
# Binding dimensions to set on the image input layer.
# infer-dims=3;192;192
infer-dims=1;192;192
# parse-bbox-func-name=NvDsInferParseLandmarks
# custom-lib-path=nvdsinfer_landmark_parser/libnvdsinfer_landmark_parser.so
# Color format required by the model Integer 0: RGB 1: BGR 2: GRAY
model-color-format=2
num-detected-classes=1
#nw type Integer 0: Detector 1: Classifier 2: Segmentation 3: Instance Segmentation 100=Other
network-type=100
# Gst-nvinfer attaches raw tensor output as Gst Buffer metadata.
output-tensor-meta=1
When calling
gst_element_set_state (pipeline, GST_STATE_PLAYING);
gst_element_get_state (pipeline, NULL, NULL, GST_CLOCK_TIME_NONE);
the program doesn’t return from the second line. However when changing output-tensor-meta=0 in sgie config things work as expected except I don’t have the tensor meta output which I needed. What’s wrong with that stuff? I altered the deepstream-infer-tensor-meta-test’s pgie config to
network-type=1
which works and I suppose gives me more or less the same setup as in my app which doesn’t. Any help appreciated. I’m stuck on this already for a while now.
I installed probes on sgies src and sink pad and could see that the first frame was actually passed through the sink but not through the src so there must be a deadlock in nvinfer, probably due to my config. Is there any way to dive deeper into that debugging-wise? I’d like to have some indication why this is not working.
The problem may be with your model. Since you are using onnx model, is your model dynamic batch or fixed batch? ‘cluster-mode’ and ‘infer-dims’ are of no use for your case, you don’t need to set them. How did you train and generate your onnx mode? Why did you set ‘detected-max-w=0’ and ‘detected-max-h=0’ in pgie?
Hey Fiona,
thanks for getting back on this. The model is provided by my co-worker. I try to query him on that stuff. However, I made some discoveries: I compiled gst-nvinfer with debugging flag and debugged it. It’s the same thing as here except I’m not having this custom function. It seems that in my setup this always happens for the 11th NvDsObjectMeta in gstnvinder.cpp:1533. If I remove all but the first 5 or 6 bboxes returned by the bbox parser in PGIE it works. No deadlock and everything runs smoothly.
I altered my PGIE config to this but still things remain:
[property]
gpu-id=0
batch-size=1
network-mode=0
interval=0
gie-unique-id=1
network-type=0
Why do I not need to set infer-dims? I would need to scale my bboxes to fit the model requirements before feeding them into sgie right?
No. You don’t need to fill this for onnx model. gst-nvinfer will read the dimensions from onnx model directly, you don’t need to fill this. This is for uff model and other models.
And perhaps this Raw tensor output - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums may help you.
The one I used has fixed batch size. However my co-worker provided my one with dynamic batch size meanwhile. Still the error remains. Do I need to have the batch-size property in the sgie config file using the dynamic batching? However this
looks promising. I’ll give it a try.
Ok. I solved it by increasing
batch-size=200
in sgie config.
