Pipeline Hangs at set_state(PLAYING) in Threaded Multi-Pipeline Setup Using create_uridecode_bin
I’m encountering a runtime issue using DeepStream with Python bindings. I’m running two DeepStream pipelines in separate Python threads, and I’m dynamically creating the source using a function called create_uridecode_bin(index, filename). One pipeline consistently works, but the second pipeline intermittently gets stuck when calling pipeline.set_state(Gst.State.PLAYING) — this happens 2 out of 5 times.
There’s no crash or visible error — just a silent hang, likely during an async state transition. It seems to be waiting for a preroll that never completes.
def decodebin_child_added(child_proxy,Object,name,user_data):
print(“Decodebin child added:”, name, “\n”)
if(name.find(“decodebin”) != -1):
Object.connect(“child-added”,decodebin_child_added,user_data)
if(name.find(“nvv4l2decoder”) != -1):
if (platform_info.is_integrated_gpu()):
Object.set_property(“enable-max-performance”, True)
Object.set_property(“drop-frame-interval”, 0)
Object.set_property(“num-extra-surfaces”, 0)
else:
Object.set_property(“gpu_id”, GPU_ID)
def cb_newpad(decodebin,pad,data):
global streammux
print(“In cb_newpad\n”)
caps=pad.get_current_caps()
gststruct=caps.get_structure(0)
gstname=gststruct.get_name()
# Need to check if the pad created by the decodebin is for video and not
# audio.
print("gstname=",gstname)
if(gstname.find("video")!=-1):
    source_id = data
    pad_name = "sink_%u" % source_id
    print(pad_name)
    #Get a sink pad from the streammux, link to decodebin
    sinkpad = streammux.request_pad_simple(pad_name)
    if not sinkpad:
        sys.stderr.write("Unable to create sink pad bin \n")
    if pad.link(sinkpad) == Gst.PadLinkReturn.OK:
        print("Decodebin linked to pipeline")
    else:
        sys.stderr.write("Failed to link decodebin to pipeline\n")
def create_uridecode_bin(index,filename):
global g_source_id_list
print(“Creating uridecodebin for [%s]” % filename)
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
g_source_id_list[index] = index
bin_name="source-bin-%02d" % index
print(bin_name)
# Source element for reading from the uri.
# We will use decodebin and let it figure out the container format of the
# stream and the codec and plug the appropriate demux and decode plugins.
bin=Gst.ElementFactory.make("uridecodebin", bin_name)
if not bin:
    sys.stderr.write(" Unable to create uri decode bin \n")
# We set the input uri to the source element
bin.set_property("uri",filename)
# Connect to the "pad-added" signal of the decodebin which generates a
# callback once a new pad for raw data has been created by the decodebin
bin.connect("pad-added",cb_newpad,g_source_id_list[index])
bin.connect("child-added",decodebin_child_added,g_source_id_list[index])
#Set status of the source to enabled
g_source_enabled[index] = True
return bin
Please provide complete information as applicable to your setup. Thanks
Hardware Platform (Jetson / GPU)
DeepStream Version
JetPack Version (valid for Jetson only)
TensorRT Version
NVIDIA GPU Driver Version (valid for GPU only)
Issue Type( questions, new requirements, bugs)
How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
