Please provide complete information as applicable to your setup. • Hardware Platform: dGPU
**• DeepStream Version: 7.0 ** • TensorRT Version: 8.6.1 • NVIDIA GPU Driver Version: 550 • Issue Type: bugs
My pipeline stopped when one of my source connect and get warning Color primaries 5 not present and will be treated BT.601 . It look something like this. If
**PERF: {'stream0': 0.0, 'stream1': 0.0, 'stream2': 0.0, 'stream3': 20.41}
Warning: Color primaries 5 not present and will be treated BT.601
**PERF: {'stream0': 4.05, 'stream1': 0.0, 'stream2': 0.0, 'stream3': 8.2}
**PERF: {'stream0': 0.0, 'stream1': 0.0, 'stream2': 0.0, 'stream3': 0.0}
Here is my log and pipeline graph: gs.log (1.5 MB)
output.dot.txt (214.1 KB)
The state change started from streaming_bin_3. I dont know what caused this, maybe the h264 source is corrupted but i dont want my whole pipeline to go down if one source is corrupted.
Thanks for your suggestion. The tiler branch is for multistream visualize. while the others branch after demuxer is for full frame image saving with bounding box. So
with your suggestion, what should i do to replace tee after metamux? Should i just do
