Thanks for reply. I got new information about the crash.I will show below.
I create pipeline just like deepstream-app-test3:
bool CDlg_GeneralDisplay::InitPipeLine(CamPipeline *CamConfig){
int current_device = -1;
cudaGetDevice(¤t_device);
struct cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, current_device); //Nidia官方CUDA代码,用来识别设备是不是Jetson
// CamConfig->Loop = NULL; //初始化变量
CamConfig->Pipeline = NULL;
CamConfig->streammux = NULL;
CamConfig->sink = NULL;
CamConfig->pgie = NULL;
CamConfig->queue1 = NULL;
CamConfig->queue2 = NULL;
CamConfig->queue3 = NULL;
CamConfig->queue4 = NULL;
CamConfig->queue5 = NULL;
CamConfig->nvvidconv = NULL;
CamConfig->nvosd = NULL;
CamConfig->transform = NULL;
CamConfig->nvtracker = NULL;
CamConfig->bus = NULL;
CamConfig->osd_sink_pad = NULL;
// CamConfig->Loop = g_main_loop_new (NULL, FALSE); //标准的Gsteamer初始化流程 在此初始化主循环
CamConfig->Pipeline = gst_pipeline_new ("PipeLine"); //给创建的管道命名
CamConfig->streammux = gst_element_factory_make ("nvstreammux", "stream-muxer"); //创建nvstreammux混合器用于Batch推理或者混流
if (!CamConfig->Pipeline || !CamConfig->streammux){ //判断是否创建成功,不成功就返回且弹窗
QMessageBox::warning(this, tr("Warning"), tr("Failed to create Streammux & Pipeline."),QMessageBox::Ok);
return false;
gst_bin_add (GST_BIN (CamConfig->Pipeline), CamConfig->streammux); //把Streammux添加到Bin箱柜
CamConfig->source_bin = create_source_bin (0, CamConfig->SourceUrl); //创建视频源头箱柜
if (!CamConfig->source_bin) {
QMessageBox::warning(this, tr("Warning"), tr("Failed to create Source_Bin."),QMessageBox::Ok);
return false;
gst_bin_add (GST_BIN (CamConfig->Pipeline), CamConfig->source_bin); //添加视频源头箱柜到管道
g_snprintf (CamConfig->pad_name, 15, "sink_%u", 0);
CamConfig->sinkpad = gst_element_get_request_pad (CamConfig->streammux, CamConfig->pad_name);
//获取指定element中的指定pad的名称
if (!CamConfig->sinkpad) {
QMessageBox::warning(this, tr("Warning"), tr("Streammux request sink pad failed. "),QMessageBox::Ok);
return false;
CamConfig->srcpad = gst_element_get_static_pad (CamConfig->source_bin, "src"); //获取指定element中的指定pad的名称
if (!CamConfig->srcpad) {
QMessageBox::warning(this, tr("Warning"), tr("Failed to get src pad of source bin."),QMessageBox::Ok);
return false;
if (gst_pad_link (CamConfig->srcpad, CamConfig->sinkpad) != GST_PAD_LINK_OK) { //如果mux组和src组连接失败就报错
QMessageBox::warning(this, tr("Warning"), tr("Failed to link source bin to stream muxer."),QMessageBox::Ok);
return false;
gst_object_unref (CamConfig->srcpad);
gst_object_unref (CamConfig->sinkpad);
CamConfig->pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine"); //设置Nvinfer推理组件
CamConfig->nvtracker = gst_element_factory_make ("nvtracker", "tracker"); //设置Nvtracker跟踪组件
CamConfig->queue1 = gst_element_factory_make ("queue", "queue1"); //每两个组件之间设置缓冲队列
CamConfig->queue2 = gst_element_factory_make ("queue", "queue2");
CamConfig->queue3 = gst_element_factory_make ("queue", "queue3");
CamConfig->queue4 = gst_element_factory_make ("queue", "queue4");
CamConfig->queue5 = gst_element_factory_make ("queue", "queue5");
CamConfig->nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter"); //NV12转化RGB插件
CamConfig->nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay"); //NVOSD绘制插件
if(prop.integrated) {
CamConfig->transform = gst_element_factory_make ("nvegltransform", "nvegl-transform"); //如果是Jetson硬件就额外创建转化插件
CamConfig->sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer"); //显示窗口插件
if (!CamConfig->pgie || !CamConfig->nvtracker || !CamConfig->nvvidconv || !CamConfig->nvosd || !CamConfig->sink) {
QMessageBox::warning(this, tr("Warning"), tr("One of the deepstream elements could not be created."),QMessageBox::Ok);
return false;
if(!CamConfig->transform && prop.integrated) {
QMessageBox::warning(this, tr("Warning"), tr("One jetson plantform element could not be created. Exiting."),QMessageBox::Ok);
return false;
//以下均为Deeptream插件详细配置代码
g_object_set (G_OBJECT (CamConfig->streammux), "batch-size", 1, NULL);
g_object_set (G_OBJECT (CamConfig->streammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
g_object_set (G_OBJECT (CamConfig->pgie),
"config-file-path", "./Model/PrimaryInfer/yolov5s.txt", NULL);
g_object_get (G_OBJECT (CamConfig->pgie), "batch-size", &CamConfig->pgie_batch_size, NULL);
if (CamConfig->pgie_batch_size != 1) {
g_object_set (G_OBJECT (CamConfig->pgie), "batch-size", 1, NULL);
g_object_set (G_OBJECT (CamConfig->nvosd), "process-mode", OSD_PROCESS_MODE,
"display-text", OSD_DISPLAY_TEXT, NULL);
g_object_set (G_OBJECT (CamConfig->sink), "qos", 0, NULL);
if (!set_tracker_properties(CamConfig->nvtracker)) {
QMessageBox::warning(this, tr("Warning"), tr("Failed to set tracker properties."),QMessageBox::Ok);
return false;
CamConfig->bus = gst_pipeline_get_bus (GST_PIPELINE (CamConfig->Pipeline));
CamConfig->bus_watch_id = gst_bus_add_watch (CamConfig->bus, bus_call, CamConfig->Loop);
gst_object_unref (CamConfig->bus);
gst_bin_add_many (GST_BIN (CamConfig->Pipeline),
CamConfig->queue1, CamConfig->pgie, CamConfig->queue2,
CamConfig->nvtracker, CamConfig->queue3, CamConfig->nvvidconv,
CamConfig->queue4, CamConfig->nvosd, CamConfig->queue5,
CamConfig->transform, CamConfig->sink, NULL);
if (!gst_element_link_many (
CamConfig->streammux, CamConfig->queue1, CamConfig->pgie,
CamConfig->queue2, CamConfig->nvtracker, CamConfig->queue3,
CamConfig->nvvidconv, CamConfig->queue4, CamConfig->nvosd,
CamConfig->queue5, CamConfig->transform, CamConfig->sink,
NULL)) {
QMessageBox::warning(this, tr("Warning"), tr("Elements could not be linked."),QMessageBox::Ok);
return false;
}else {
CamConfig->queue5, CamConfig->sink, NULL)) {
return false;
gst_video_overlay_set_window_handle (GST_VIDEO_OVERLAY (CamConfig->sink), CamConfig->Window_ID);
CamConfig->osd_sink_pad = gst_element_get_static_pad (CamConfig->nvosd, "sink");
if (!CamConfig->osd_sink_pad)
QMessageBox::warning(this, tr("Warning"), tr("Unable to get sink pad."),QMessageBox::Ok);
else
gst_pad_add_probe (CamConfig->osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
tiler_src_pad_buffer_probe, NULL, NULL);
gst_object_unref (CamConfig->osd_sink_pad);
return true;
And i destroy pipeline by the code below:
gst_element_set_state (CamConfig.Pipeline, GST_STATE_NULL);
gst_object_unref (GST_OBJECT (CamConfig.Pipeline));
g_source_remove (CamConfig.bus_watch_id);
I have used QT to debug for hour and hours,finally found all of the crash caused by “gst_element_set_state (CamConfig.Pipeline, GST_STATE_NULL)”
At first i think maybe my code cause memory leaks or used NULL ptr.
But after enabled the GST_DEBUG = 2,I found the crash caused by nveglglessink!
Here is the debug info.
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_iou.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
0:01:08.974516488 26221 0x7e501c0ca0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT data 3x640x640
1 OUTPUT kFLOAT prob 6001x1x1
0:01:08.974846281 26221 0x7e501c0ca0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:08.981265619 26221 0x7e501c0ca0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:./Model/PrimaryInfer/yolov5s.txt sucessfully
0:01:08.982921589 26221 0x7e501c0ca0 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: source
Decodebin child added: decodebin8
0:01:08.984058999 26221 0x7e501c0ca0 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: mpegpsdemux8
Decodebin child added: multiqueue8
Decodebin child added: h264parse8
Decodebin child added: capsfilter8
Decodebin child added: nvv4l2decoder8
Opening in BLOCKING MODE
0:01:09.120146855 26221 0x7f180045e0 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder8:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:09.120258855 26221 0x7f180045e0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ee64d4380 Failed to determine interlace mode
0:01:09.120341928 26221 0x7f180045e0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ee64d4380 Failed to determine interlace mode
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
0:01:09.226783370 26221 0x7f180045e0 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder8:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:09.226907467 26221 0x7f180045e0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ee64d4380 Failed to determine interlace mode
0:01:09.226986891 26221 0x7f180045e0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ee64d4380 Failed to determine interlace mode
In cb_newpad
0:01:09.230545200 26221 0x7f180045e0 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder8> Duration invalid, not setting latency
0:01:09.232970356 26221 0x7f180045e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<nvv4l2decoder8:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:01:09.256720088 26221 0x7e400274a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder8:pool:src> Driver should never set v4l2_buffer.field to ANY
IOU Tracker Init with threshold 0.100000
0:01:09.685287752 26221 0x7e400274a0 WARN videodecoder gstvideodecoder.c:2780:gst_video_decoder_prepare_finish_frame:<nvv4l2decoder8> decreasing timestamp (0:01:03.573044444 < 0:01:04.093044444)
Using winsys: x11
0:01:11.297992172 26221 0x558e1b1a30 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:11.298219180 26221 0x558e1b1a30 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:11.321387120 26221 0x558e1b1a30 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:./Model/PrimaryInfer/yolov5s.txt sucessfully
0:01:11.324113908 26221 0x558e1b1a30 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: decodebin9
0:01:11.325442646 26221 0x558e1b1a30 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: mpegpsdemux9
Decodebin child added: multiqueue9
Decodebin child added: h264parse9
Decodebin child added: capsfilter9
Decodebin child added: nvv4l2decoder9
0:01:11.523274021 26221 0x7f2402bd40 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder9:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:11.523459941 26221 0x7f2402bd40 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ed0024ef0 Failed to determine interlace mode
0:01:11.523585157 26221 0x7f2402bd40 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ed0024ef0 Failed to determine interlace mode
0:01:11.634951056 26221 0x7f2402bd40 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder9:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:11.635080304 26221 0x7f2402bd40 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ed0024ef0 Failed to determine interlace mode
0:01:11.635242512 26221 0x7f2402bd40 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ed0024ef0 Failed to determine interlace mode
In cb_newpad
0:01:11.638527541 26221 0x7f2402bd40 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder9> Duration invalid, not setting latency
0:01:11.655704303 26221 0x7f2402bd40 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<nvv4l2decoder9:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:01:11.689382627 26221 0x558e672280 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder9:pool:src> Driver should never set v4l2_buffer.field to ANY
0:01:12.247621786 26221 0x558e672280 WARN videodecoder gstvideodecoder.c:2780:gst_video_decoder_prepare_finish_frame:<nvv4l2decoder9> decreasing timestamp (0:01:03.933044444 < 0:01:04.493044444)
Using winsys: x11
0:01:13.803584361 26221 0x7f1c0022d0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:13.803820489 26221 0x7f1c0022d0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:13.827969966 26221 0x7f1c0022d0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:./Model/PrimaryInfer/yolov5s.txt sucessfully
0:01:13.829987185 26221 0x7f1c0022d0 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: decodebin10
0:01:13.832171669 26221 0x7f1c0022d0 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: mpegpsdemux10
Decodebin child added: multiqueue10
Decodebin child added: h264parse10
Decodebin child added: capsfilter10
Decodebin child added: nvv4l2decoder10
0:01:13.960961946 26221 0x7ed50e8990 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder10:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:13.961118042 26221 0x7ed50e8990 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ea0004970 Failed to determine interlace mode
0:01:13.961229082 26221 0x7ed50e8990 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ea0004970 Failed to determine interlace mode
0:01:14.067455677 26221 0x7ed50e8990 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder10:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:14.067592029 26221 0x7ed50e8990 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ea0004970 Failed to determine interlace mode
0:01:14.067662526 26221 0x7ed50e8990 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ea0004970 Failed to determine interlace mode
In cb_newpad
0:01:14.070979299 26221 0x7ed50e8990 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder10> Duration invalid, not setting latency
0:01:14.084732536 26221 0x7ed50e8990 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<nvv4l2decoder10:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:01:14.104897847 26221 0x7f240035e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder10:pool:src> Driver should never set v4l2_buffer.field to ANY
0:01:14.396197685 26221 0x7f240035e0 WARN videodecoder gstvideodecoder.c:2780:gst_video_decoder_prepare_finish_frame:<nvv4l2decoder10> decreasing timestamp (0:01:03.573044444 < 0:01:04.133044444)
Using winsys: x11
0:01:16.368090980 26221 0x7ecc053460 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:16.368412708 26221 0x7ecc053460 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:16.376804465 26221 0x7ecc053460 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:./Model/PrimaryInfer/yolov5s.txt sucessfully
0:01:16.378339572 26221 0x7ecc053460 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: decodebin11
0:01:16.381341528 26221 0x7ecc053460 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: mpegpsdemux11
Decodebin child added: multiqueue11
Decodebin child added: h264parse11
Decodebin child added: capsfilter11
Decodebin child added: nvv4l2decoder11
0:01:16.528598522 26221 0x7f240428f0 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder11:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:16.528709498 26221 0x7f240428f0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7eb4025530 Failed to determine interlace mode
0:01:16.528789754 26221 0x7f240428f0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7eb4025530 Failed to determine interlace mode
0:01:16.635618174 26221 0x7f240428f0 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder11:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:16.636056831 26221 0x7f240428f0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7eb4025530 Failed to determine interlace mode
0:01:16.636333727 26221 0x7f240428f0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7eb4025530 Failed to determine interlace mode
In cb_newpad
0:01:16.639409060 26221 0x7f240428f0 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder11> Duration invalid, not setting latency
0:01:16.640286789 26221 0x7f240428f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<nvv4l2decoder11:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:01:16.660486340 26221 0x7f240408f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder11:pool:src> Driver should never set v4l2_buffer.field to ANY
0:01:17.018512425 26221 0x7f240408f0 WARN videodecoder gstvideodecoder.c:2780:gst_video_decoder_prepare_finish_frame:<nvv4l2decoder11> decreasing timestamp (0:01:03.773044444 < 0:01:04.293044444)
Using winsys: x11
0:01:18.405993786 26221 0x558e42f390 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:18.406256314 26221 0x558e42f390 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:18.441083888 26221 0x558e42f390 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:./Model/PrimaryInfer/yolov5s.txt sucessfully
0:01:18.443200595 26221 0x558e42f390 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: decodebin12
0:01:18.444353301 26221 0x558e42f390 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: mpegpsdemux12
Decodebin child added: multiqueue12
Decodebin child added: h264parse12
Decodebin child added: capsfilter12
Decodebin child added: nvv4l2decoder12
0:01:18.594367259 26221 0x7f24003540 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder12:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:18.594499547 26221 0x7f24003540 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ed8359900 Failed to determine interlace mode
0:01:18.594618844 26221 0x7f24003540 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ed8359900 Failed to determine interlace mode
0:01:18.701709504 26221 0x7f24003540 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder12:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:18.701823904 26221 0x7f24003540 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ed8359900 Failed to determine interlace mode
0:01:18.701975392 26221 0x7f24003540 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ed8359900 Failed to determine interlace mode
In cb_newpad
0:01:18.706191495 26221 0x7f24003540 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder12> Duration invalid, not setting latency
0:01:18.719482523 26221 0x7f24003540 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<nvv4l2decoder12:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:01:18.736721590 26221 0x7f1c004990 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder12:pool:src> Driver should never set v4l2_buffer.field to ANY
0:01:19.019754120 26221 0x7f1c004990 WARN videodecoder gstvideodecoder.c:2780:gst_video_decoder_prepare_finish_frame:<nvv4l2decoder12> decreasing timestamp (0:01:03.693044444 < 0:01:04.213044444)
Using winsys: x11
0:01:20.511287802 26221 0x7ed5380870 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:20.511468762 26221 0x7ed5380870 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:20.547316369 26221 0x7ed5380870 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:./Model/PrimaryInfer/yolov5s.txt sucessfully
0:01:20.549630805 26221 0x7ed5380870 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: decodebin13
0:01:20.551393592 26221 0x7ed5380870 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: mpegpsdemux13
Decodebin child added: multiqueue13
Decodebin child added: h264parse13
Decodebin child added: capsfilter13
Decodebin child added: nvv4l2decoder13
0:01:20.712526639 26221 0x7e3c003ed0 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder13:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:20.712649775 26221 0x7e3c003ed0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7f203bb320 Failed to determine interlace mode
0:01:20.712735375 26221 0x7e3c003ed0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7f203bb320 Failed to determine interlace mode
0:01:20.820233141 26221 0x7e3c003ed0 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder13:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:20.820378005 26221 0x7e3c003ed0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7f203bb320 Failed to determine interlace mode
0:01:20.820482805 26221 0x7e3c003ed0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7f203bb320 Failed to determine interlace mode
In cb_newpad
0:01:20.823534330 26221 0x7e3c003ed0 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder13> Duration invalid, not setting latency
0:01:20.835069451 26221 0x7e3c003ed0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<nvv4l2decoder13:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:01:20.852149958 26221 0x7f1c004ad0 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder13:pool:src> Driver should never set v4l2_buffer.field to ANY
0:01:21.152636307 26221 0x7f1c004ad0 WARN videodecoder gstvideodecoder.c:2780:gst_video_decoder_prepare_finish_frame:<nvv4l2decoder13> decreasing timestamp (0:01:03.573044444 < 0:01:04.093044444)
Using winsys: x11
0:01:22.401582482 26221 0x7f2800fc40 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:22.401757906 26221 0x7f2800fc40 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /home/jetson/Desktop/Project/build-AI_System-Desktop-Debug/Model/PrimaryInfer/yolov5s_fp16.engine
0:01:22.426900505 26221 0x7f2800fc40 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:./Model/PrimaryInfer/yolov5s.txt sucessfully
0:01:22.428516347 26221 0x7f2800fc40 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: decodebin14
0:01:22.429479421 26221 0x7f2800fc40 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: mpegpsdemux14
Decodebin child added: multiqueue14
Decodebin child added: h264parse14
Decodebin child added: capsfilter14
Decodebin child added: nvv4l2decoder14
0:01:22.571218231 26221 0x7f24042800 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder14:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:22.571315159 26221 0x7f24042800 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ec83632a0 Failed to determine interlace mode
0:01:22.571484375 26221 0x7f24042800 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ec83632a0 Failed to determine interlace mode
0:01:22.683602339 26221 0x7f24042800 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:<nvv4l2decoder14:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:01:22.683720356 26221 0x7f24042800 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ec83632a0 Failed to determine interlace mode
0:01:22.683805828 26221 0x7f24042800 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7ec83632a0 Failed to determine interlace mode
In cb_newpad
0:01:22.686379432 26221 0x7f24042800 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder14> Duration invalid, not setting latency
0:01:22.701327423 26221 0x7f24042800 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<nvv4l2decoder14:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:01:22.726185669 26221 0x7f24003f20 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder14:pool:src> Driver should never set v4l2_buffer.field to ANY
0:01:22.852577703 26221 0x7ec0019990 WARN nveglglessink gsteglglessink.c:443:gst_egl_image_buffer_pool_alloc_buffer: Fallback memory allocation
** (AI_System:26221): WARNING **: 23:41:09.290: Use gst_egl_image_allocator_alloc() to allocate from this allocator
0:01:22.854362666 26221 0x7ec0019990 WARN GST_BUFFER gstbuffer.c:907:gst_buffer_new_allocate: failed to allocate 8294400 bytes
0:01:22.854476938 26221 0x7ec0019990 WARN videopool gstvideopool.c:272:video_buffer_pool_alloc:<eglimagebufferpool14> can't create memory
0:01:22.854515018 26221 0x7ec0019990 WARN bufferpool gstbufferpool.c:310:do_alloc_buffer:<eglimagebufferpool14> alloc function failed
0:01:22.854553002 26221 0x7ec0019990 WARN bufferpool gstbufferpool.c:343:default_start:<eglimagebufferpool14> failed to allocate buffer
0:01:22.854579882 26221 0x7ec0019990 ERROR bufferpool gstbufferpool.c:564:gst_buffer_pool_set_active:<eglimagebufferpool14> start failed
0:01:22.854734058 26221 0x7ec0019990 WARN basetransform gstbasetransform.c:1670:default_prepare_output_buffer:<nvegl-transform> error: failed to activate bufferpool
0:01:22.854784811 26221 0x7ec0019990 WARN basetransform gstbasetransform.c:1670:default_prepare_output_buffer:<nvegl-transform> error: failed to activate bufferpool
0:01:22.855079819 26221 0x7ec0019990 WARN basetransform gstbasetransform.c:2159:default_generate_output:<nvegl-transform> could not get buffer from pool: error
realloc(): invalid next size
Aborted (core dumped)
root@jetson-desktop:/home/jetson/Desktop/Project/build-AI_System-Desktop-Debug# ^C
