Pipeline UDP sink generates many h264 errors
Both Orin AGX and laptop with A5000
• DeepStream Version
6.3
5.1.2
• TensorRT Version
laptop: 8.6.1.6-cuda 12.0 jetson: 8.5.2.2 + cuda 11.4
570.124.06
I have a deepstream pipeline for which I’m trying to add a UDP sink. Specifically, I’m interested in getting a plain mpeg transport stream, not an rtsp / rtp stream. I modelled the sink portion based on the create_udpsink_bin function in deepstream_sink_bin.c. (this link is the same file, but appears to be an older version of deepstream (not the example I actually pulled from: deepstream-4.0.1/sources/apps/apps-common/src/deepstream_sink_bin.c at master · Kwull/deepstream-4.0.1 · GitHub)
My actual source code is:
  tl::expected<GstElement*, std::string> create_sink(const UdpSink& us) {
    logger_->info("[create_sink] adding udp sink");
    GstElement* udp_sink_bin = gst_bin_new("udp_sink_bin");
    // ************************** create udp sink queue element ***********************************
    GstElement* sink_queue = gst_element_factory_make("queue", "udp_sink_queue");
    if (!sink_queue) {
      return tl::unexpected("[create_sink] Failed to create udp_sink_queue");
    gst_bin_add(GST_BIN(udp_sink_bin), sink_queue);
    // link queue element to bin ghost pad
    GstPad* queue_sink_pad = gst_element_get_static_pad(sink_queue, "sink");
    if (!queue_sink_pad) {
      return tl::unexpected("[create_sink][udp sink] failed to get queue sink pad");
    // create the sink pad of our sink bin and connect it to the tee
    if (!gst_element_add_pad(udp_sink_bin, gst_ghost_pad_new("sink", queue_sink_pad))) {
      return tl::unexpected("[create_sink][udp] Failed to add ghost pad in udp sink bin");
    gst_object_unref(queue_sink_pad);
    // ************************** create udp sink convert element **********************************
    GstElement* nvconv = gst_element_factory_make("nvvideoconvert", "udp_nvvideoconvert");
    if (!nvconv) {
      return tl::unexpected("[create_sink][udp] Failed to create nvvideoconvert");
    gst_bin_add(GST_BIN(udp_sink_bin), nvconv);
    if (!gst_element_link(sink_queue, nvconv)) {
      return tl::unexpected("[create_sink][udp] Failed to link sink queue->nvvideoconvert");
    // ************************** create udp sink caps filter **************************************
    GstElement* capsfilter = gst_element_factory_make("capsfilter", "udp_capsfilter");
    if (!capsfilter) {
      return tl::unexpected("[create_sink][udp] Failed to create udp_capsfilter");
    // caps for h264 HW decoder
    GstCaps* caps = gst_caps_from_string("video/x-raw(memory:NVMM), format=I420");
    g_object_set(G_OBJECT(capsfilter), "caps", caps, NULL);
    gst_bin_add(GST_BIN(udp_sink_bin), capsfilter);
    if (!gst_element_link(nvconv, capsfilter)) {
      return tl::unexpected("[create_sink][udp] Failed to link sink nvvideoconvert->capsfilter");
    gst_caps_unref(caps);
    // ************************** create udp sink encoder element **********************************
    GstElement* encoder = gst_element_factory_make("nvv4l2h264enc", "nvv4l2h264enc");
    if (!encoder) {
      return tl::unexpected("[create_sink] Failed to create nvv4l2h264enc");
    g_object_set(G_OBJECT(encoder), "bitrate", (gint)us.bitrate, NULL);
    g_object_set(G_OBJECT(encoder), "profile", 0, NULL);
    g_object_set(G_OBJECT(encoder), "iframeinterval", 5, "idrinterval", 5, NULL);
    if (is_jetson_gpu_) {
      g_object_set(G_OBJECT(encoder), "preset-level", 1, NULL);
      g_object_set(G_OBJECT(encoder), "insert-sps-pps", 1, NULL);
    } else {
      g_object_set(G_OBJECT(nvconv), "gpu-id", 0, NULL);
    gst_bin_add(GST_BIN(udp_sink_bin), encoder);
    if (!gst_element_link(capsfilter, encoder)) {
      return tl::unexpected("[create_sink][udp] Failed to link sink caps_filter->nvv4l2h264enc");
    // ************************** create udp sink h264parse element ********************************
    GstElement* parser = gst_element_factory_make("h264parse", "h264parse");
    if (!parser) {
      return tl::unexpected("[create_sink] Failed to create h264parse for udp sink");
    g_object_set(G_OBJECT(parser), "config-interval", -1, NULL);
    gst_bin_add(GST_BIN(udp_sink_bin), parser);
    if (!gst_element_link(encoder, parser)) {
      return tl::unexpected("[create_sink][udp] Failed to link nvv4l2h264enc->h264parse");
    // ************************** create udp sink mpegtsmux element ********************************
    GstElement* mpegtsmux = gst_element_factory_make("mpegtsmux", "mpegtsmux");
    if (!mpegtsmux) {
      return tl::unexpected("[create_sink][udp] Failed to create mpegtsmux for udp sink");
    gst_bin_add(GST_BIN(udp_sink_bin), mpegtsmux);
    // get the h264parse src pad to link to
    GstPad* parser_src_pad = gst_element_get_static_pad(parser, "src");
    if (!parser_src_pad) {
      return tl::unexpected("[create_sink][udp sink] failed to get h264parse src pad");
    // request a sink pad from mpegtsmux
    GstPad* sink_pad = gst_element_get_request_pad(mpegtsmux, "sink_%d");
    if (!sink_pad) {
      gst_object_unref(parser_src_pad);
      return tl::unexpected("[create_sink][udp] failed to request sink pad on mpegtsmux");
    if (auto res = gst_pad_link(parser_src_pad, sink_pad); res != GST_PAD_LINK_OK) {
      gst_object_unref(sink_pad);
        fmt::format("[create_sink][udp] Linking of h264parse src and mpegtsmux sink pads failed. "
                    "GstPadLinkReturn value: {}",
                    (int)res));
    // ************************** create udp sink element ******************************************
    GstElement* udp_sink = gst_element_factory_make("udpsink", "udpsink");
    g_object_set(G_OBJECT(udp_sink), "host", us.host.c_str(), "port", us.port, "async", FALSE,
                 "sync", 0, NULL);
    if (!udp_sink) {
      return tl::unexpected("[create_sink] Failed to create udpsink element");
    gst_bin_add(GST_BIN(udp_sink_bin), udp_sink);
    if (!gst_element_link(mpegtsmux, udp_sink)) {
      return tl::unexpected("[create_sink][udp] Failed to link mpegtsmux -> udp_sink");
    return udp_sink_bin;
Sinks bin of the final pipeline running on my laptop (sink bin is similar when running from jetson):
I’ve limited my pipeline to 5 fps. Outside, of that, the source and inference portions of the pipeline are pretty standard. My overall sink bin has a tee with a fakesink, optionally a Display Sink and then optionally the UDP sink. I am running my pipeline inside a docker container.
When trying to view the UDP stream on another system, there are many h.264 decoding errors and the output looks terrible. This is the output from ffplay (gstreamer with a playbin element doesn’t seem to be able to handle all the errors):
results are similar if I run the pipeline from my laptop to my jetson or my jetson to the laptop. If I stream from the laptop just to outside the docker container and then view the stream on my laptop, the results are much better, but still have a few errors and doesn’t seem to be quite right. Any pointers on what elements I might not have setup correctly would be appreciated.
This problem is more likely to be caused by the network packet loss. You can do a simple experiment to save the video locally to see if that gets similar problems.
I tried streaming from inside the docker container to outside the docker container and while the problem was less significant it was still there. Also, the network between the jetson and the laptop was a very good network, but I’m going to try a direct link.
Is it possible that packets are being dropped from the stream because they’re somehow “late”? ping time between the jetson and my laptop is < 2ms but maybe that’s enough? when the picture is good there’s easily 4-5 seconds of latency between the what’s shown in the display sink and the udp sink (when I’m streaming to just outside the container) which seems insane for being on the machine.
Do you have a monitor attached to your jetson board? This problem is most likely the udp packet loss problem. You can try to display on your jetson board to verify this first.
I agree it’s a packet loss problem, the hard part is where the packets are being lost. It seems at least one issue was on my configuration of the mpegtsmux element. For streaming UDP, it appears that the alignment property needs to be set to 7 to avoid excessively small packets. (I’ve cross posted this question on the gstreamer forums:
changing that and adding a queue upstream of mpegtsmux, streaming from my laptop → jetson, things get significantly better. There are still a few packet losses, but it’s not bad.
These same changes when streaming from the jetson → laptop, definitely help, but there are still a lot of packets being lost.
This pipeline works relatively well from the jetson->laptop:
gst-launch-1.0 videotestsrc is-live=true ! video/x-raw,width=1280,height=720,framerate=30/1 ! nvvideoconvert ! nvv4l2h264enc bitrate=4000000 preset-level=3 idrinterval=30 ! h264parse config-interval=-1 ! queue ! mpegtsmux alignment=7 ! queue ! udpsink host=10.100.101.52 port=15004
which is a little surprising given it streams at 30fps, not 5fps like my actual pipeline.
It definitely adds a couple seconds of latency which is not desirable.
Thanks for your verification. From that, it looks more like a problem with the udpsink and mpegtsmux plugin in Gstreamer. You can follow your topic in the Gstreamer forum. Thanks
