Pixal3D (image-to-3D) on DGX Spark: what it takes on GB10, and why low_vram should be off
Tencent ARC’s Pixal3D turns one image into a textured 3D mesh (GLB), and it keeps the input’s own viewpoint, so the front of the model lines up with the picture. I ran it on objects cut out of public-domain paintings, first on an RTX 4090, then on a Spark.
On the 4090 it only ran in low_vram mode at resolution 1024, and the 24 GB card could not hold the upstream default (low_vram off, 1536). On the Spark the default ran. Getting there took a CUDA 12.9 toolkit and a newer Triton, because the torch 2.7 (cu128) in this setup doesn’t know GB10 yet.
Repo with the config and the full write-up: MindrLabs/image-to-3d-pixal3d
Van Gogh’s chair from The Bedroom (1889), the 3D front, and the same 3D from the side. It keeps the painting’s own perspective, so it leans back once you walk around it.
Short version
  • 3–7 min per model on the Spark with the same settings as the 4090 (low_vram on, 1024). The 4090 did the same inputs in 136–143 s.
  • Turn low_vram off on a Spark. With it on, the worker’s RSS reached 89.6 GiB and was killed once at the 100 GiB cap I set. With it off at 1536, the whole machine used about 47 GiB and made three models in a row.
  • 1536 ran on the Spark, but it didn’t look clearly better at render size. Both settings reduce the output to 1M faces and a 4096 texture.
  • Two things break on GB10 out of the box: CUDA extensions won’t build against torch cu128 with only CUDA 13 on the system, and Triton 3.3.1 (bundled with torch 2.7) crashes on sm_121.
How long it takes
Same settings on both machines (low_vram on, generation resolution 1024, seed 7):
Input Input read size DGX Spark RTX 4090
The Bedroom chair 512 169 s 143 s
The Bedroom chair 1024 176 s failed (RAM cap)
Claesz skull 512 392 s 136 s
Claesz skull 1024 420 s failed (RAM cap)
The skull took more than twice as long as the chair on the Spark, while the two were close on the 4090. I didn’t find out why. This run used Triton 3.5.1 (the 4090 used the stock 3.3.1), and with low_vram on the worker sat close to my memory cap.
With low_vram off at 1536 (the upstream default), three paintings took 255, 273 and 305 s. Those three ran without a warmup, so treat them as rough numbers.
Top to bottom: chair on the 4090 (low_vram, 1024) and on the Spark (low_vram off, 1536), then a Heda still life and a Seurat watering can in the same order. Shapes are nearly the same; colours differ in places.
Memory: low_vram works against you on unified memory
low_vram keeps the stage models in system RAM and moves each stage to the GPU when needed. On a 24 GB card that’s the only way it fits. On the Spark, CPU and GPU share the same memory, so the copies don’t save anything:
  • low_vram on: worker RSS 89.6 GiB after six generations (five warmups and one result). The seventh briefly went over my 100 GiB cap and the worker was killed. Two later server starts each made six generations without hitting it, so it peaks rather than keeps growing.
  • low_vram off, 1536: about 47 GiB for the whole machine (free, one moment during generation).
These are not the same measure (process RSS can include mapped weight files), so take the comparison as a direction, not a ratio.
Also: nvidia-smi --query-compute-apps reported 17.7–18.0 GiB for the server either way, and the whole-device GPU memory reads [N/A] on GB10. On a Spark that number doesn’t tell you how much memory the job holds.
Getting it to run on GB10
What I did, in order. Paths are examples. Run model-compose up once first: it creates the model’s venv (.venv/pixal3d) and installs torch 2.7.1+cu128, then stops at the torchvision step described below.
1. A CUDA 12.9 toolkit next to the system CUDA 13 (torch 2.7.1+cu128 won’t build extensions with nvcc 13; 12.9 is the first that knows sm_121). No sudo needed:
wget https://developer.download.nvidia.com/compute/cuda/12.9.1/local_installers/cuda_12.9.1_575.57.08_linux_sbsa.run
sh cuda_12.9.1_575.57.08_linux_sbsa.run --silent --toolkit --toolkitpath=$HOME/cuda-12.9 --no-man-page --override
export CUDA_HOME=$HOME/cuda-12.9 PATH=$HOME/cuda-12.9/bin:$PATH
export TORCH_CUDA_ARCH_LIST=12.0   # torch 2.7 doesn't know 12.1; sm_120 binaries run on GB10
2. flash-attn and natten from source. There are no prebuilt aarch64 wheels for these versions. Build them into the model’s venv before the first full start (about 66 + 7 min with MAX_JOBS=8):
PY=.venv/pixal3d/bin/python
$PY -m pip install "torchvision==0.22.1" --index-url https://download.pytorch.org/whl/cu128
FLASH_ATTN_CUDA_ARCHS=120 MAX_JOBS=8 $PY -m pip install --no-build-isolation --no-binary flash-attn "flash-attn==2.8.3.post1"
NATTEN_CUDA_ARCH=12.0 NATTEN_N_WORKERS=8 $PY -m pip install --no-build-isolation "natten==0.21.0"
Note on torchvision: on aarch64 the cu128 index publishes torchvision-0.22.1 without the +cu128 tag that x86 wheels carry, so an installer that pins ==0.22.1+cu128 finds nothing. I installed the plain 0.22.1 as above and had to make the installer accept it. I’ll update this post when that’s handled upstream.
3. Triton 3.5.1 with the 12.9 ptxas. With the stock Triton 3.3.1, the worker dies at the texture stage:
'sm_121a' is not a recognized processor for this target (ignoring processor)
LLVM ERROR: Cannot select: intrinsic %llvm.nvvm.cp.async.commit.group
Triton 3.5.1 generates sm_121a code, but its bundled ptxas (12.8) then fails with Value 'sm_121a' is not defined for option 'gpu-name'. Point it at the 12.9 one:
$PY -m pip install --no-deps "triton==3.5.1"
export TRITON_PTXAS_PATH=$CUDA_HOME/bin/ptxas
4. Start it with those variables set. The first start builds the remaining CUDA extensions (CuMesh, FlexGEMM, nvdiffrast, o_voxel), which took roughly 10 minutes here. The 46 GB of weights were already on the machine, so I can’t say how long the download takes.
git clone https://github.com/MindrLabs/image-to-3d-pixal3d
cd image-to-3d-pixal3d
# set low_vram: false (and resolution: 1536 if you want the upstream default) in model-compose.yml
model-compose up
Background removal uses the gated briaai/RMBG-2.0 (non-commercial license), so accept it on Hugging Face and hf auth login first.
Setup and how it was measured
  • DGX Spark: GB10, 128 GB unified memory, aarch64, system CUDA 13.0. Shared machine.
  • model-compose 0.4.113, the official Pixal3D compose. torch 2.7.1+cu128, CUDA 12.9 toolkit for building, Triton 3.5.1.
  • 100 GiB memory cap on the server (systemd scope), because low_vram on a 64 GB 4090 box once froze the whole machine.
  • Times are per model, after warmup (repeated 2–5 times until generation time settles) and model loading. The three 1536 runs had no warmup.
  • Each input generated once, seed 7. Results judged from four-angle renders.
  • Not measured: 1536 with low_vram on, low_vram off at 1024, seed-to-seed variation, multi-view input.
Two questions for people running TRELLIS-family models on a Spark:
  1. Has anyone got the torch 2.7 / Triton 3.3 stack working on sm_121 without swapping Triton? I’d rather not mix versions if there’s a cleaner route.
  2. Any idea why the skull took 2.9× the 4090’s time while the chair took 1.2×? Same settings, same seed.
