Using PLL multiplier and PLL pre/post dividers:
MCLK multiplier = PLL multiplier / PLL pre-divider / PLL post-divider
pixel_clk_hz = MCLK × MCLK multiplier
For example:
MCLK = 24MHz
PLL multiplier = 30
PLL pre-divider = 3
PLL post-divider = 3
Then:
MCLK multiplier = 30 / 3 / 3 = 6.67
pixel_clk_hz = 24000000 × 6.67 = 160000000
Using sensor CSI lane output rate:
pixel_clk_hz = sensor data rate per lane (Mbps) * number of lanes / bits per pixel
For example:
Sensor data rate = 891 Mbps (per lane)
Number of lanes = 4
Bits per pixel = 10
Then pixel_clk_hz = 891 Mbps × 4 / 10 = 356400000
Using frame size and frame rate
pixel_clk_hz = sensor output size × frame rate
The above is the method for calculating pix frequency. I have a few questions:
Does the sensor data rate per lane represent the speed of the channel?
Depending on the version, the maximum speed of the standard CSI lane channel is 1.5Gbps or 2.5Gbps/lane.Where can I obtain the sensor data rate per lane (Mbps) value if I want to calculate pixel_clk_hz?
Sensor output size = 2200 × 1125
(actual output size 1920 × 1080)
Frame rate = 30 frames/second
pixel_clk_hz = 2200 × 1125 × 30 = 74250000
My camera resolution is 960 * 960 now, how should I confirm the sensor output size of the camera?
