Pixel clock
I am working on project consisting of multiple SDI cameras, FPGA, MIPI interface and jetson. Cameras with no specific resolution (max fullhd) or frame rate (max 60 fps) will be used.
I would like if someone could clarify me impact of pixel clock frequency on the resulting functionality. Is it possbile to set it to higher value so it would always be higher than actual number of pixel per second? The idea is to set it to constant and high enough frequency for all possible formats cameras could have.
Thank you.
Suppose yes, but we don’t support SDI camera, may need bridge transfer to CSI.
Thak you for fast response.
Bridge from SDI to CSI will be done in FPGA.
One more question. What will be side effects of this workaround?
Should be no any side effects.
