Pixel Phase and Video Color output Orin Nano dev kit
I have an interesting situation. I have a video stream and FFMPEG pipeline that “work” and produce a color output on CSI-0 of an Orin Nano dev kit.
The DT is set to YUYV for the pixel phase however I have to run with the rawvideo option and uyvy422 as the pixel_format in the FFMPEG pipeline in order to get decent output. I then have to deinterlace and crop the image in the pipeline. Just curious why this is the case. I need to find a better answer as there are horizontal artifacts in the final image when there is motion or lighting changes.
We are uncertain how ffmpeg works. This would need other users to share experience.
You may try gstreamer and see if it works as expected:
Jetson AGX Orin FAQ
