Which of these log lines are produced as a result of plugging in the device?
[ 32.716035] usb 2-1.4: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[ 32.743141] usb 2-1.4: New USB device found, idVendor=8086, idProduct=0b5c, bcdDevice=50.e0
[ 32.743150] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 32.743154] usb 2-1.4: Product: Intel(R) RealSense(TM) Depth Camera 455
[ 32.743158] usb 2-1.4: Manufacturer: Intel(R) RealSense(TM) Depth Camera 455
[ 32.743161] usb 2-1.4: SerialNumber: 221123061353
[ 32.801355] input: Intel(R) RealSense(TM) Depth Ca as /devices/platform/3610000.xhci/usb2/2-1/2-1.4/2-1.4:1.0/input/input24
[ 32.819904] usbcore: registered new interface driver uvcvideo
[ 32.819909] USB Video Class driver (1.1.1)
[ 51.611636] usb 1-2.3: new full-speed USB device number 4 using tegra-xusb
[ 51.725250] usb 1-2.3: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
[ 51.725257] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 51.725262] usb 1-2.3: Product: FT232R USB UART
[ 51.725265] usb 1-2.3: Manufacturer: FTDI
[ 51.725268] usb 1-2.3: SerialNumber: A50285BI
[ 51.758431] usbserial: exports duplicate symbol usb_serial_resume (owned by kernel)
Just for reference, vendor ID 0x8086 is Intel (an interesting number to link to Intel since the 8086 was one of Intel’s origins), and 0x0b5c is not listed (which would mean it is a newer product; typically, unless you’ve installed something for udev
to recognize this product ID, then no driver could be selected since the existing database does not associate a driver-to-chipset assignment).
The next part with vendor ID 0x0403 is one I would expect. This is vendor FTDI, probably the most well-known UART manufacturer (their UARTs are usually supported by default). That product ID is for “6001 FT232 Serial (UART) IC
”. FTDI naming convention is “/dev/ttyUSB#
” (where “#
” starts at 0
). The ttyACM#
is a different vendor’s chipset.
Normally the device plugin log would also meantion which ttyUSB#
is assigned. What do you see from:
ls -l /dev/ttyUSB*
The part which might be confusing the system, even if everything else is correct, is indicated here:
This sounds like maybe there is a module trying to produce a symbol which already exists in the kernel itself. If the module has different source code, e.g., it is from a patch or has a bug workaround, then one would need to first remove the symbol which is integrated into the kernel in a non-module format. This is something I would not advise doing (it is a lot of work compared to adding a module) unless you know the default version which exists integrated into the kernel has some flaw that the module is intended to work around.
Notice how the ID vendor/product “8086:0b5c
” results in this:
The same thing is replaced by the duplicate symbol warning. The module cannot insert because there is already a driver. I don’t see earlier mention of ft232
, and so it seems the integrated driver did not find this hardware (or if it did, it did not mention the hardware). Remember how I said that the USB database I looked at did not know what that particular product ID is? It is possible the driver build into the kernel would succeed if it had that ID knowledge (I don’t know for sure that the kernel is using the same table of IDs I am looking at, but probably it is). Perhaps this is what the external module is set up for: To recognize that product ID without consulting an outside table (I don’t know for sure, but it seems likely this is what any patch is for).
Sometimes a patch or a pseudo driver (my term, it isn’t a real term; I’m implying something about picking a driver rather than providing one) will update udev
to add an association between an unknown vendor/product ID and a driver. Useful when the driver itself is correct, and the system just doesn’t know this. Or one could edit the driver itself and add this ID combination so the ID database itself does not need this. The latter is useful in some cases, but not really advisable if not needed since the driver might get updated and lose that knowledge.
So I have these questions:
- Did you add another driver in the form of a module? If so, was it something intended as a workaround or perhaps was supplied by a third party? If so, then you will need to rebuild and install an entirely new kernel
and all modules, followed by adding this module (which means the module will then be able to load; there won’t be a duplicate symbol).
- What is the output of “
ls -l /dev/ttyUSB*
”? I ask because if a file by that name exists, then maybe the driver integrated into the kernel already created this, and it is equivalent to the ttyACM*
file, and just uses a different chipset.
