Planning Configuration cuMotion
ompl_planning_pipeline_config = {
    "move_group": {
        "planning_plugin": "ompl_interface/OMPLPlanner",
        "request_adapters":
        """default_planner_request_adapters/AddTimeOptimalParameterization default_planner_request_adapters/FixWorkspaceBounds default_planner_request_adapters/FixStartStateBounds default_planner_request_adapters/FixStartStateCollision default_planner_request_adapters/FixStartStatePathConstraints""",
        "start_state_max_bounds_error": 0.1,
ompl_planning_yaml = load_yaml("ar_moveit_config",
                               "config/ompl_planning.yaml")
ompl_planning_pipeline_config["move_group"].update(ompl_planning_yaml)
If i want to add cumotion below change right?
    "move_group": {
        "request_adapters":
    "planning_pipelines": ["ompl", "isaac_ros_cumotion"],
# Add cuMotion to list of planning pipelines.
cumotion_config_file_path = load_yaml("ar_moveit_config",
                               "config/isaac_ros_cumotion_planning.yaml")
ompl_planning_pipeline_config["isaac_ros_cumotion"] = cumotion_config_file_path
That looks correct. Please let us know if you hit any issues.
I use the config and use isaac_ros_cumotion_moveit, the problem come out
