I draw a plant and contain three parts,and i have three texture png file on them,when i merge these parts to a single parts,the texture dispear,how can i fix it.
Hammad_M
2
A single mesh can only have one material on it, so if you want to have three separate textures I would recommend not merging.
Related topics
| Isaac Sim Merge Mesh Tool not assigning materails | 0 | 61 | August 6, 2024 | |
| Merge 2 meshes using Action Graph | 0 | 105 | July 8, 2024 | |
| About applying texture to each face of the cylinder | 1 | 969 | May 23, 2022 | |
| Same material looks different on 2 objects | 6 | 855 | June 16, 2022 | |
| Is there a way to Merge Sub Items of a Group together? | 4 | 689 | July 7, 2024 | |
| Merge mesh tool missing | 2 | 493 | December 7, 2022 | |
| Crash with more than one Blender Material node | 0 | 413 | February 16, 2023 | |
| Read material when making uv's | 10 | 1367 | September 16, 2021 | |
| Hairworks Stand share mesh Vertices with other Lines ( but thats not True)(Pictures attached) | 0 | 498 | January 21, 2019 | |
| Create 2022.3.0 | More than one Mtlx Image - Current Limitation? | 4 | 589 | November 29, 2022 |
