I have ported U-Boot by downloading the U-Boot source code from git and making the modifications mentioned in the guide. I am not sure if this is the right way to do it or if linux systems already have these source files stored somewhere which I should modify?
Also, I tried a similar approach to port the Linux Kernel.The instructions in the guide says:
From the arch/arm64/boot/dts/tegra210-platforms/ directory, copy each
file whose name has the form:
tegra210-jetson-cv----.dtsi
Copy each file to:
arch/arm64/boot/dts/tegra210-platforms/tegra210--
.dtsi
Inside the source files for linux kernel, which I downloaded from git, I don’t see tegra210-platforms
directory. However, there is an nvidia directory, but it doesn’t seem to have a dtsi file corresponding to any kind of . At this point I am pretty sure I have taken a wrong turn somewhere. Kindly provide guidance.
Those instructions appear to be from an older release, e.g., R24.2. What release are you using?
FYI, the driver package comes with file “source_sync.sh” (JetPack downloads the driver package, but I just download the driver package by itself). You can use this to download both kernel and U-Boot source for R28.2 (current release) via:
I have downloaded the source for R28.2 (release that I am using). And the instructions being used are from the guide posted by @kaycc. The reason why I am confused is because a lot of details mentioned in the guide doesn’t match what I am seeing in the source directory structure. I have made a lot of assumptions so far to proceed. I am looking for better instruction set if available.
