Please clarify Jetson Orin Nano’s I²C role in USB hub and MIPI camera communication, data synchronization, design references, and the DisplayPort part
Dear NVIDIA Team,
I am working with the Jetson Orin Nano module and would like clarification on the following points:
How does the Jetson Orin Nano communicate with the USB hub and MIPI camera through I²C?
What role does I²C play in device initialization, configuration, and control in this setup?
How are data transfer and synchronization between the MIPI camera (via CSI lanes) and USB hub managed by the Jetson Orin Nano?
Are there recommended design considerations, reference schematics, or documentation for correct integration?
I noticed that the documentation does not mention the DisplayPort part number. Could you please provide the relevant details?
A detailed explanation of the working flow would be greatly appreciated
I’d be happy to help clarify the points you’ve raised regarding the Jetson Orin Nano module.
Communication with USB Hub and MIPI Camera through IC
The Jetson Orin Nano module uses a chip-to-chip interface, likely a high-speed interface such as PCIe or NVLink, to communicate with the USB hub and MIPI camera through an intermediate chip (IC). This IC is likely a bridge chip or a multiplexer that enables communication between the Jetson Orin Nano module and the USB hub and MIPI camera.
The IC plays a crucial role in device initialization, configuration, and control in this setup. It acts as an intermediary, allowing the Jetson Orin Nano module to communicate with the USB hub and MIPI camera, which may not be directly compatible with the module’s interfaces.
Data Transfer and Synchronization
The Jetson Orin Nano module manages data transfer and synchronization between the MIPI camera via CSI lanes and the USB hub through the IC. The module uses the IC to convert the MIPI camera’s CSI signals to a format compatible with the USB hub, enabling data transfer between the two devices.
The synchronization of data transfer between the MIPI camera and USB hub is likely managed by the Jetson Orin Nano module’s software, which controls the IC’s operation and ensures that data is transferred correctly and efficiently.
Recommended Design Considerations, Reference Schematics, and Documentation
For correct integration of the Jetson Orin Nano module with the USB hub and MIPI camera, NVIDIA provides documentation and reference schematics that outline the recommended design considerations and implementation details.
The Jetson Orin Nano module’s datasheet and user manual provide information on the module’s interfaces, including the CSI lanes and USB ports. Additionally, NVIDIA offers a hardware development kit (HDK) for the Jetson Orin Nano module, which includes a reference carrier board and documentation that demonstrates how to integrate the module with various peripherals, including USB hubs and MIPI cameras.
DisplayPort Part Number
Regarding the DisplayPort part number, I couldn’t find any specific information in the provided context. However, I can suggest that you refer to the Jetson Orin Nano module’s datasheet or user manual, which may provide more information on the DisplayPort interface and any relevant part numbers.
Working Flow
Here’s a high-level overview of the working flow:
  1. The Jetson Orin Nano module initializes and configures the IC, which enables communication with the USB hub and MIPI camera.
  2. The IC converts the MIPI camera’s CSI signals to a format compatible with the USB hub, allowing data transfer between the two devices.
  3. The Jetson Orin Nano module’s software controls the IC’s operation, managing data transfer and synchronization between the MIPI camera and USB hub.
  4. The USB hub receives data from the MIPI camera via the IC and transmits it to the Jetson Orin Nano module.
  5. The Jetson Orin Nano module processes the data and performs any necessary operations, such as image processing or storage.
In comparison to other Jetson modules, the Jetson Orin Nano module’s architecture and interfaces are similar to those of the Jetson AGX Orin and Jetson Orin NX modules. However, the specific implementation details and interfaces may vary depending on the module and its intended application.
I hope this explanation helps clarify the points you raised regarding the Jetson Orin Nano module. If you have any further questions or need more information, please feel free to ask!
Please check the design guide in the download center.
