Please Help an Independent Developer from Ukraine Continue Building AI Systems
Hello NVIDIA team,
I’m an independent developer from Ukraine, working alone on different experimental AI systems.
Right now, I have an idea that I really want to build, but the current limit of 40 requests per minute is not enough for it. The system uses multiple AI agents that work in parallel, compare ideas, criticize each other’s answers, and then produce a final result.
I’m not a professional programmer. I build these systems with the help of AI, then test everything myself, find problems, improve the ideas, and learn along the way.
I also don’t have a large public GitHub profile or commercial projects to show. Most of the things I create are personal tools, experiments, and research projects that I build for myself.
I cannot afford expensive API usage. I live in Ukraine, and a large part of my income goes toward basic living expenses. Access to NVIDIA’s models gives me a real opportunity to continue learning and building things that would otherwise be unavailable to me.
I understand that you may not be able to increase the limit for every account, but I would be very grateful if you could review my request and increase it to 200 RPM, or to any higher limit that is available.
Thank you for your time and for providing access to these models.
