Please help me enable DTS to support SPI2
Is the physical address mapping for this SPI controller correct?
Hi zhangpeng5,
You can refer to https://elinux.org/Jetson/L4T/peripheral/#Mapping for SPI mapping.
AGX Orin has similar SPI address as Orin NX/Nano.
We are using custom board for AGX Orin
We wanted to use SPI2, so I added the following content to DTS, and /dev/spidev2.0 appeared. I used spidev_test to test, but the waveform output was not there. Please tell me where the problem lies.
the test command as below
sudo ./spidev_test -D /dev/spidev0.0 -v -p "HelloWorld123456789abcdef"
                            spi@c260000 {
                                    status = "okay";
                                    spi@0 {
                                            compatible = "tegra-spidev";
                                            reg = <0x00>;
                                            status = "okay";
                                            spi-max-frequency = <0x2faf080>;
                                            controller-data {
                                                    nvidia,enable-hw-based-cs;
                                                    nvidia,rx-clk-tap-delay = <0x10>;
                                                    nvidia,tx-clk-tap-delay = <0x00>;
~0408
Why you said that you are using /dev/spidev2.0 but you specified /dev/spidev0.0 in the test command?
Please share the full dmesg and the result of ls -l /dev/spidev* on your board.
