#!/usr/bin/env python
# Copyright (c) 2019-2022, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
import RPi.GPIO as GPIO
import time
output_pins = {
'JETSON_XAVIER': 18,
'JETSON_NANO': 33,
'JETSON_NX': 33,
'CLARA_AGX_XAVIER': 18,
'JETSON_TX2_NX': 32,
'JETSON_ORIN': 18,
'JETSON_ORIN_NX': 33,
'JETSON_ORIN_NANO': 33
output_pin = output_pins.get(GPIO.model, None)
if output_pin is None:
raise Exception('PWM not supported on this board')
def main():
# Pin Setup:
# Board pin-numbering scheme
GPIO.setmode(GPIO.BOARD)
# set pin as an output pin with optional initial state of HIGH
GPIO.setup(output_pin, GPIO.OUT, initial=GPIO.HIGH)
p = GPIO.PWM(output_pin, 1000)
val = 50
incr = 5
p.start(val)
print("PWM running. Press CTRL+C to exit.")
try:
while True:
time.sleep(1.0)
finally:
p.stop()
GPIO.cleanup()
if __name__ == '__main__':
main()
This is the code I am using, I am on AGX orin 64gb devkit and jetpack version 6.2.2, I have checked everything is configured correctly. Also, if I use normal GPIO pins such as 31 and jetgpio library, I can generate correct wave. All of the pins are correctly configured also. Any idea? It always shows 50 Mhz sine wave and does not stop even if I stop programm, but If I remove jumper and insert agan the sine wave stops. is it some EMI interference?
