Our customers use the 32.5.0 version of the BSP, but the latest cbbot source that can be found is version 32.4.4. Is there a newer version of cboot source available?
Can customers use the 32.4.4 version of cboot source on the 32.5.0 version of the BSP?
Please help, thanks
Hi aaron.ge,
Please get the source code from download center:
thank you for your support!
Our customer uses the 32.5.0 version of BSP, but the latest cbbot source that can be found is version 32.4.4. Is there a newer version of cboot source code available?
Can customers use the 32.4.4 version of the cboot source on the 32.5.0 version of the BSP?
Please help, thanks
It’s published, I can find the Cboot source 32.5 from the link I pasted. Can you check again?
No, there is always dependencies, thus can’t work.
I can’t see the cboot source code of version 32.5. The latest one is 32.4.4. Can you send me the file directly? Thank you
Hi aaron.ge,
Here is the link for Cboot source 32.5 - CBoot Sources for Jetson AGX Xavier and Jetson Xavier NX
Not sure why you can find it, please clear all caches and cookies to refresh the browser, then see if can see it from download center.
