Please tell me how to enable DP port in Jetson
Please tell me how to enable DP port in Jetson.
Adapter : Jetson nano ==> DPv1.2 to HDMIv2.0 ==> HDMIv2 Cable ==> 4K UHD Monitor
DC in: 5 DCV 5A
DP port is already enabled on jetson nano devkit by default. There is no need to “enable” it again.
The monitor is not connected to the DP port.
What should I check?
Don’t know what you are asking here. If it is not connected to the DP port, then why you asked a DP problem?
I want to connect UHD 4K Monitor to Jetson nano DP port.
The connection method was connected with Jetson ==> DPv1.2 to HDMIv2.0 ==> HDMIv2 Cable ==> Monitor.
The monitor cannot be connected.
It asks how to connect the monitor to the DP Port.
We don’t have any recommended adapter for DP to HDMI.
I will let other users to share their experience.
