Hi all,
Firstly, any help regarding this issue im facing is truly appreciated.
Bearing in mind im pretty new with meddling with GPU settings, here’s my issue as summarized with my topic title. Basically i need to use a software thats kinda old. It will only function with CUDA enabled systems. Now i find out only GTX CUDA cards. I have an RTX 1060 so as you can imagine, the software is not detecting CUDA from my card.
So my question obviously is, is there a solution for this? Can i enable my RTX card somehow?
Once again, thank you.
John
