I have Tensorflow ops ResizeArea, Select, Fill, and Equal used in my Tensorflow model.
When model was converted to uff, got warnings as
Warning: No conversion function registered for layer: ResizeArea yet.
Converting upsample_heatmat as custom op: ResizeArea
Warning: No conversion function registered for layer: Select yet.
Converting Select as custom op: Select
Warning: No conversion function registered for layer: Fill yet.
Converting zeros_like as custom op: Fill
Warning: No conversion function registered for layer: Equal yet.
Converting Equal as custom op: Equal
So plugins are created for ResizeArea, Select, Fill, and Equal.
Then plugins are mapped to Tensorflow ops as
class ModelData(object):
INPUT_NAME = "image"
EQUAL_NAME = "Equal"
SELECT_NAME = "Select"
PMAT_NAME = "upsample_pafmat"
ZERO_LIKE = "zeros_like"
HMAT_NAME = "upsample_heatmat"
OUTPUT_NAME = "Openpose/output"
def prepare_namespace_plugin_map():
# In this sample, the only operation that is not supported by TensorRT
# is tf.nn.relu6, so we create a new node which will tell UffParser which
# plugin to run and with which arguments in place of tf.nn.relu6.
# The "clipMin" and "clipMax" fields of this TensorFlow node will be parsed by createPlugin,
# and used to create a CustomClipPlugin with the appropriate parameters.
trt_resizearea = gs.create_plugin_node(name="trt_resizearea", op="ResizeAreaPlugin", in_width=80.0, in_height=60.0, in_channel=3.0, upscale=4.0)
trt_fill = gs.create_plugin_node(name="trt_fill", op="FillPlugin", in_width=320.0, in_height=240.0, in_channel=3.0, value=0.0)#fill 0
trt_equal = gs.create_plugin_node(name="trt_equal", op="EqualPlugin", in_width=320.0, in_height=240.0, in_channel=3.0)
trt_select = gs.create_plugin_node(name="trt_select", op="SelectPlugin", in_width=320.0, in_height=240.0, value=0.0)
namespace_plugin_map = {
ModelData.SELECT_NAME: trt_select,
ModelData.EQUAL_NAME: trt_equal,
ModelData.PMAT_NAME: trt_resizearea,
ModelData.HMAT_NAME: trt_resizearea,
ModelData.ZERO_LIKE: trt_fill
return namespace_plugin_map
def model_to_uff(model_path):
# Transform graph using graphsurgeon to map unsupported TensorFlow
# operations to appropriate TensorRT custom layer plugins
dynamic_graph = gs.DynamicGraph(model_path)
dynamic_graph.collapse_namespaces(prepare_namespace_plugin_map())
# Save resulting graph to UFF file
output_uff_path = model_path_to_uff_path(model_path)
uff.from_tensorflow(
dynamic_graph.as_graph_def(),
[ModelData.OUTPUT_NAME],
output_filename=output_uff_path,
text=True
return output_uff_path
def model_path_to_uff_path(model_path):
uff_path = os.path.splitext(model_path)[0] + ".uff"
return uff_path
Why I still have warnings as
Warning: No conversion function registered for layer: ResizeAreaPlugin yet.
Converting trt_resizearea as custom op: ResizeAreaPlugin
W0808 17:44:51.442725 139793630279424 deprecation_wrapper.py:119] From /home/coie/Data/coie/Softwares/venv/lib/python3.5/site-packages/uff/converters/tensorflow/converter.py:179: The name tf.AttrValue is deprecated. Please use tf.compat.v1.AttrValue instead.
Warning: No conversion function registered for layer: SelectPlugin yet.
Converting trt_select as custom op: SelectPlugin
Warning: No conversion function registered for layer: FillPlugin yet.
Converting trt_fill as custom op: FillPlugin
Warning: No conversion function registered for layer: EqualPlugin yet.
Converting trt_equal as custom op: EqualPlugin
What could be wrong?
