Plugin Shared Library Not Found
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
Hi, i have implemented plugin for Tile layer and successfully build the .so file.
I also have successfully build and run the network in RTX 2080.
But now i have problem when i try to run it on AGX Pegasus. It says
DW_FILE_NOT_FOUND: DNNPlugin: Shared library not found: cannot open shared object file: no such file
I attached the error message below. (You see i ls the pluginPath and its exist)
And my implementation for load the plugin is like this
    dwDNNPluginConfiguration pluginConf{};
    pluginConf.numCustomLayers = 1;
    std::string pluginPath = argsLidarPlugin;
    std::cout << "Plugin path: " << pluginPath << std::endl;
    dwDNNCustomLayer customLayer{};
    customLayer.pluginLibraryPath = pluginPath.c_str();
    pluginConf.customLayers = &customLayer;
    CHECK_DW_ERROR(dwDNN_initializeTensorRTFromFile(&m_dnn_pfe, pfeOnnxFilePath.c_str(), &pluginConf, DW_PROCESSOR_TYPE_GPU, DWHandles.m_context));
For your information, i compile the project using gpu RTX2080 and then copy the compiled program and plugin.so to AGX.
What might cause the issue? Thanks i need help ASAP
Dear @user142014,
Could you share file <sofile> and ls -la <sofile>
@SivaRamaKrishnaNV
Dear @user142014,
I see the shared library is for x86 architecture and not aarch64. Could you cross compile to get shared library for aarch64?
