Point cloud in CSV file as output (only data driven)
I have a set of 3d CFD simulations of a seawater intake, in which I have parameterized the speed of the seawater current and the suction speed of the seawater intake, from the simulations I have extracted a cloud of points with position information (x, y, z) and its respective velocity magnitude for each simulation, this in CSV format.
Each point cloud information is in a separate csv file.
I want to train a neural network with two input variables (the speeds that I have mentioned) and as output variable a cloud of points with the variables indicated above (x, y, z) and speed magnitude.
My question is how to tell modulus that my output is a csv file that contains the information of the cloud of points.
Hi @matiyanez
Yes you can make data-driven models inside of Modulus. CSV is a great format for the data to be in.
Reading from a CSV is done in a lot of our examples for reference, such as the cylinder flow problem.
