what’s your datastructure for int **values. int **values can be a pointer to one array of int’s… but it can also be an array of pointers to arrays of ints. Latter means that your data is probably not stored continuous - so your routine copies only the values[0] and not values[1] to values[end].
If you are passing a “double dimensional” array which was declared as “array[NUM][NUM]” then you canNOT pass it as “int **”. The way the compiler generates code for “int **” is different from what it generates for “int ”. Try passing that array as “int values”
the datastructure for int** values is a pointer to array of int but although it seems that the data ist’t stored in memory continous … and it wae declared as int** … i try to use a temporary array whithout a pointer to pass it …
