Pointer Arrays in CUDA Fortran
Hi, all
I need to deal with lots of data which consists of column vectors with different length. As a result, it’s not appropriate to use the two-dimension array. The pointer arrays seems can solve the problem perfectly. Although, it’s not possible to declare an array of pointers in Fortran, we can create an pointer array by using derived data types as the sample routine does.
PROGRAM test_array_pointer
  IMPLICIT NONE
  TYPE :: ptr
    REAL, POINTER :: p(:)
  END TYPE
  TYPE(ptr), ALLOCATABLE :: x(:)
  REAL, TARGET :: a(1)
  REAL, TARGET :: b(2)
  REAL, TARGET :: c(3)
  a=(/1.0/)
  b=(/1.0,2.0/)
  c=(/1.0,2.0,3.0/)
  ALLOCATE(x(3))
  x(1)%p => a
  x(2)%p => b
  x(3)%p => c
  WRITE(*,*)  x(1)%p
  WRITE(*,*)  x(2)%p
  WRITE(*,*)  x(3)%p
  DEALLOCATE(x)
  STOP
END PROGRAM test_array_pointer
The program output:
    1.000000
    1.000000        2.000000
    1.000000        2.000000        3.000000
FORTRAN STOP
It seems that the roundabout method works fine. Then I want to use it in CUDA Fortran, I write a test routine as follows.
PROGRAM test
  USE cudafor
  IMPLICIT NONE
  TYPE :: ptr
  END TYPE
  TYPE(ptr), DEVICE, ALLOCATABLE :: dev_x(:)
  REAL, DEVICE, TARGET :: a(1)
  REAL, DEVICE, TARGET :: b(2)
  REAL, DEVICE, TARGET :: c(3)
  REAL :: x(1)
  INTEGER :: istat
  a=(/1.0/)
  b=(/1.0,2.0/)
  c=(/1.0,2.0,3.0/)
  ALLOCATE(dev_x(3),STAT=istat)
  WRITE(*,*) istat
  dev_x(1)%p => a
  dev_x(2)%p => b
  dev_x(3)%p => c
  x = dev_x(1)%p
  WRITE(*,*) x
  DEALLOCATE(dev_x)
  STOP
END PROGRAM test
The program output:
           0
Errors occur on the memory operations, unfortunately.
BTW, the NVIDIA card is K20C and the compile enviroment shows below.
  • PGI Fortran 13.10 X64, Cent OS 6.4 X64
    -Mcuda=cuda5.5,cc35
Can someone tell me where it goes wrong?
Or is there any other ways to deal with the column vectors with different length?
Hi OceanCloud,
The basic problem here is with “dev_x(1)%p”. You’re trying to access a device data structure on the host. While the base device address of “dev_x” is stored on the host, any internal addresses are not. Hence, to make this work, you need to move these pointer assignments over to the device.
Something like the following:
% cat testp.cuf
module foo
  TYPE :: ptr
  END TYPE
  REAL, DEVICE                      :: xD(3)
  REAL, DEVICE, allocatable, TARGET :: a(:)
  REAL, DEVICE, allocatable, TARGET :: b(:)
  REAL, DEVICE, allocatable, TARGET :: c(:)
contains
  attributes(global) subroutine assignPtr()
     dev_x(1)%p => a
     dev_x(2)%p => b
     dev_x(3)%p => c
  end subroutine assign
  attributes(global) subroutine getA()
     xD(1:1)= dev_x(1)%p
  end subroutine getA
  attributes(global) subroutine getB()
     xD(1:2) = dev_x(2)%p
  end subroutine getB
  attributes(global) subroutine getC()
     xD = dev_x(3)%p
  end subroutine getC
end module foo
PROGRAM test
  USE cudafor
  use foo
  IMPLICIT NONE
  REAL :: x(3)
  INTEGER :: istat
  allocate(a(1), b(2), c(3))
  a=(/1.0/)
  b=(/1.0,2.0/)
  c=(/1.0,2.0,3.0/)
  x=0.0
  WRITE(*,*) istat
  call assignPtr<<<1,1>>>()
  xD=0.0
  call getA<<<1,1>>>()
  x=xD
  WRITE(*,*) x
  xD=0.0
  call getB<<<1,1>>>()
  x=xD
  WRITE(*,*) x
  xD=0.0
  call getC<<<1,1>>>()
  x=xD
  WRITE(*,*) x
  DEALLOCATE(dev_x,a,b,c)
  STOP
END PROGRAM test
% pgf90 -Mcuda testp.cuf -V13.9 ; a.out
            0
    1.000000        0.000000        0.000000
    1.000000        2.000000        0.000000
Warning: ieee_inexact is signaling
FORTRAN STOP
  • Mat
I know exactly where the problem is
You are a great help, Mat.
