Hi:
As far as I understand, Fortran 2008 standard lifted the restriction of rank-1 target for pointer rank remapping. I was wondering if this feature is going to be supported anytime soon by the PGI fortran compiler. If I try to compile the code below with pgfortran version 14.7, I get the error
PGF90-S-0155-Illegal POINTER assignment - rank of pointer target must be 1 or equal to rank of pointer object (ptrRankRemap.f90: 26)
0 inform, 0 warnings, 1 severes, 0 fatal for main
The code is:
program main
implicit none
integer, parameter :: nRows = 13
integer, parameter :: nCols = 6
integer, parameter :: nElts = nRows*nCols
integer, target :: A(nRows,nCols)
integer, pointer :: ptr2A(:) => null()
integer :: i, j
! initialize A
do j=1,nCols
do i=1,nRows
A(i,j) = i+(j-1)*nRows
end do
end do
! print A
print *, A
print *, ''
! pointer rank remapping
ptr2A(1:nElts) => A(:,:)
! increment elements of A by 1
ptr2A = ptr2A + 1
print *, A
end program main
Thanks,
Purnendu.
