Pointgrey camera on Jetson TX2
Hi all,
Does somebody use Pointgrey camera module with TX2 or TX1?
I have ‘image consistency error issue’ currently while using their own SDK flycapture2.
Hi myungseok,
We don’t have experience on this issue, you may contact with them to file a ticket to get the support.
https://www.ptgrey.com/support/contact-us
Hi Kaycc,
I found this command to increase the socket buffer size.
sudo sysctl -w net.core.rmem_max=33554432
sudo sysctl -w net.core.wmem_max=33554432
sudo sysctl -w net.core.rmem_default=33554432
sudo sysctl -w net.core.wmem_default=33554432
After using those commands, it works better.
I have tried the same. But i still get image consistency error on my TX1. All packets are dropped in my case. Any suggestions on how to fix it?
Hi ashwath1993,
I also increased packet delay in my code and it works.
The packet size is 1500.
