Hello. I was facing the trouble: I have a really bad performance with 3d apps when it uses Vulkan. In that time performance with OpenGL4 is good.
For example Unreal Engine 4:
Windows 10 = 100 FPS (+/- 5)
Ubuntu 18.04 (KDE Neon) with OpenGL4 target = 85-90 FPS
Ubuntu 18.04 (KDE Neon) with Vulkan taget = 25-35 FPS
Why is so big difference beetween OpenGL 4 and Vulkan ?
My hardware info:
PROCESSOR: Intel Core i7-8550U @ 4.00GHz
Core Count: 4
Thread Count: 8
Extensions: SSE 4.2 + AVX2 + AVX + RDRAND + FSGSBASE
Cache Size: 8192 KB
Microcode: 0xb4
Scaling Driver: intel_pstate powersave
GRAPHICS: NVIDIA GeForce 930MX 2GB
Frequency: 954/1001MHz
OpenGL: 4.6.0
Vulkan: 1.1.102
Display Driver: NVIDIA 430.50
Screen: 1920x1080
MOTHERBOARD: HP 837D
BIOS Version: Q85 Ver. 01.02.05
Chipset: Intel Xeon E3-1200 v6/7th
Audio: Conexant CX8200
Network: Realtek RTL8111/8168/8411 + Intel 8265 / 8275
MEMORY: 8192MB
DISK: 1000GB HGST HTS541010B7
File-System: ext4
Mount Options: relatime rw
Disk Scheduler: MQ-DEADLINE
OPERATING SYSTEM: neon 18.04
Kernel: 5.0.0-31-generic (x86_64)
Desktop: KDE Plasma 5.17.0
Display Server: X Server 1.19.6
Compiler: GCC 7.4.0 + Clang 6.0.0-1ubuntu2
Security: l1tf: Mitigation of PTE Inversion; VMX: conditional cache flushes SMT vulnerable
+ mds: Mitigation of Clear buffers; SMT vulnerable
+ meltdown: Mitigation of PTI
+ spec_store_bypass: Mitigation of SSB disabled via prctl and seccomp
+ spectre_v1: Mitigation of usercopy/swapgs barriers and __user pointer sanitization
+ spectre_v2: Mitigation of Full generic retpoline IBPB: conditional IBRS_FW STIBP: conditional RSB filling
Nvidia driver info:
Thu Oct 17 13:50:38 2019
| NVIDIA-SMI 430.50 Driver Version: 430.50 CUDA Version: 10.1 |
| 0 GeForce 930MX Off | 00000000:01:00.0 Off | N/A |
| N/A 47C P0 N/A / N/A | 506MiB / 2004MiB | 14% Default |
OpengGL and Vulkan ver.:
OpenGL version string: 4.6.0 NVIDIA 430.50
Vulkan Instance Version: 1.1.114
Please, help.
Here is duplication of the topic on Unreal Engine forum: https://answers.unrealengine.com/questions/930264/view.html
This is quite a constrained card. I can totally imagine the Vulkan Unreal 4 benchmark you’re using tipping over 2GB in Vulkan and not handling the situation as well as NVIDIA OpenGL driver.
Are you able to reproduce these performance difference on other machines with more than 2GB?
You can use the SMI command line you’ve pasted above to check the memory usage while you’re running the performance tests to see how close you are to memory being full.
Yes, I agree. But in that time I have a good perfomance with OpenGL4 or DirectX.
Unfortunately no :( I have several notebooks from HP and Lenovo, but they all have similar GPUs
Thanks for hint, I’ll try it with OpenGL4 and Vulkan and share results.
It would be cool. Which OS and drivers version are you using?
But, in same time I’m a bit confused. Because I understand if I have a poor perfomance on all hardware/software stuff, on Windows/DirectX or Linux/OpenGL, or Linux/Vulkan. But no. I have problems only with Vulkan.
Khronos told me:
Khronos only provides the api specification for Vulkan. The actual implementation is done inside the driver .
Judging from my experience with NVIDIA and Vulkan their driver is very good and performance with Vulkan is usually better than with OpenGL due to the much lower overhead.
And most of the time low Vulkan performance is an application problem, so you’d have to ask the people that implemented Vulkan in the Unreal Engine why performance is so low compared to OpenGL. Usually that’s caused by bad api usage, e.g. over-synchronization, not moving buffer data to the GPU, etc.
(also I’m trying to discuss with Epics)
A don’t think that problems due to insufficient perfomance of that GPU for that tasks (I also tried to reduce and images quality, I did tried a lot of difference driver’s configuration, I tried to reduce resolution. No significant changes with Vulkan).
So, is there any change that this problem with Vulkan of specific GPUs family?
r3d9u11
October 21, 2019, 11:14am
4
Ok, here is SMI output:
Without UE4 loaded, compositing is enabled:
| N/A 47C P0 N/A / N/A | 515MiB / 2004MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 2189 G /usr/lib/xorg/Xorg 182MiB |
| 0 2427 G /usr/bin/kwin_x11 4MiB |
| 0 2433 G /usr/bin/plasmashell 74MiB |
| 0 2498 G /usr/bin/latte-dock 17MiB |
| 0 7246 G /snap/anbox/158/usr/bin/anbox 230MiB |
Compositing is disabled, UE4 scene loaded with OpenGL4 target ~65FPS
| N/A 56C P0 N/A / N/A | 794MiB / 2004MiB | 2% Default |
| 0 2189 G /usr/lib/xorg/Xorg 185MiB |
| 0 2427 G /usr/bin/kwin_x11 1MiB |
| 0 3429 C+G ...lEngine/Engine/Binaries/Linux/UE4Editor 277MiB |
Compositing is disabled, UE4 scene loaded with Vulkan target ~25-30FPS :
| N/A 53C P0 N/A / N/A | 1111MiB / 2004MiB | 2% Default |
| 0 2189 G /usr/lib/xorg/Xorg 190MiB |
| 0 6243 C+G ...lEngine/Engine/Binaries/Linux/UE4Editor 586MiB |
r3d9u11
October 21, 2019, 11:21am
5
