Pop!_OS 20.04 is based on Ubuntu 20.04 LTS.
I followed the install guide https://docs.nvidia.com/datacenter/cloud-native/container-toolkit/install-guide.html#docker
Setting up Docker with:
curl https://get.docker.com | sh \
&& sudo systemctl --now enable docker
went well.
Setting up nvidia container toolkit using:
distribution=$(. /etc/os-release;echo $ID$VERSION_ID) \
&& curl -fsSL https://nvidia.github.io/libnvidia-container/gpgkey | sudo gpg --dearmor -o /usr/share/keyrings/nvidia-container-toolkit-keyring.gpg \
&& curl -s -L https://nvidia.github.io/libnvidia-container/experimental/$distribution/libnvidia-container.list | \
sed 's#deb https://#deb [signed-by=/usr/share/keyrings/nvidia-container-toolkit-keyring.gpg] https://#g' | \
sudo tee /etc/apt/sources.list.d/nvidia-container-toolkit.list
failed, with a message telling that the OS is not supported.
- Kernel version from
uname -a
[Linux pop-os 5.17.5-76051705-generic #202204271406~1653440576~20.04~6277a18-Ubuntu SMP PREEMPT Thu Ma x86_64 x86_64 x86_64 GNU/Linux ]
NVSMI LOG:
Timestamp : Sun Jan 22 17:38:59 2023
Driver Version : 470.141.03
CUDA Version : 11.4
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : NVIDIA GeForce GTX 1660 Ti - [Client: Docker Engine - Community
Version: 20.10.23 - NVIDIA packages version from
dpkg -l '*nvidia*'
[ 470.141.03-1pop0~1660260989~20.04~d973896, nvidia-cuda-dev 10.1.243-3, nvidia-settings 470.57.01-0ubuntu0.20.04.3, system76-driver-nvidia 20.04.62~1661449829~20.04~0337294 ]
