I am trying to develop using the TX2 NX card. I noticed the card has the pads for the SD card slot but it is not populated. Could I purchase a micro-SD card connector such as this and be able to use micro-SD as external storage or even to boot from?
We don’t suggest to do any change on module.
I realize I would risk damaging the module, but my question is would the device be able to access the SD card if I populate that connector? Would the BSP allow it to be found?
No, it will not.
