I have array C1[16]and in the kernel I try to copy the element of the C1 into the local memory C, and the I copy one element of local memory to the output buffer
NDRange globalNDRange(16);
NDRange localNDRange(8);
and the kernel code is:
int ar2 = get_global_id(0);
__local float C[BLOCK_SIZE]; // BLOCK_SIZE is 16
//copy c array..............
if(ar2 <12 )
C[ar2] = C1[ar2];
barrier(CLK_LOCAL_MEM_FENCE);
O[ar2]= C[2];// where C[2] = 1
and the output is:
idx = value(C[2]=1)
0 = 1
1 = 1
2 = 1
3 = 1
4 = 1
5 = 1
6 = 1
7 = 1
8 = 0
9 = 0
10 = 0
11 = 0
12 = 0
13 = 0
14 = 0
15 = 0
my question is, why the output from 7-15 is ‘0’, it should be ‘1’ since C[2] is ‘1’.
