Porting Codec from Jetpack 4 to Jetpack 5 (r35.4.1)
We are upgrading our AGX Xavier kernel from Jetpack 4 (r32.7.1) to Jetpack 5 (r35.4.1) and I am having trouble with getting our audio codec to work on the new kernel version. It is an ADAU1361 connected via the 40-pin header.
This is what has been working in r32.7.1
	i2c@31e0000 {
		adau1361_codec: adau1361@38 {
			compatible = "adi,adau1361";
			reg = <0x38>;
			clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH4>;
			clock-names = "mclk";
	i2s@2901000 {
		status = "okay";
	sound {
		assigned-clocks = <&bpmp_clks TEGRA194_CLK_PLLA_OUT0>, <&bpmp_clks TEGRA194_CLK_EXTPERIPH4>;
		assigned-clock-parents = <&bpmp_clks TEGRA194_CLK_PLLA>, <&bpmp_clks TEGRA194_CLK_PLLP_OUT0>;
		assigned-clock-rates = <0>, <24000000>;
		mclk-fs = <0>;
		nvidia,audio-routing =
			"m Headphone", "m LOUT",
			"m Headphone", "m ROUT",
			"m Mic", "m MICBIAS",
			"m LINP", "m Mic",
			"m LINN", "m Mic",
			"m RINP", "m Mic",
			"m RINN", "m Mic";
		nvidia,dai-link-2 {
			link-name = "adau1361-codec";
			cpu-dai = <&tegra_i2s2>;
			codec-dai = <&adau1361_codec>;
			cpu-dai-name = "I2S2";
			codec-dai-name = "adau-hifi";
			format = "i2s";
			bitclock-slave;
			frame-slave;
			bitclock-noninversion;
			frame-noninversion;
			bit-format = "s32_le";
			bclk_ratio = <1>;
			srate = <48000>;
			num-channel = <2>;
			ignore_suspend;
			name-prefix = "m";
			status = "okay";
This is what I’ve tried so far (following the dev guide) on r35.4.1
#include "../../galen/kernel-dts/common/tegra194-audio-p2822-0000.dtsi"
	i2c@31e0000 {
		adau1361: adau1361@38 {
			reg = <0x38>;
			#sound-dai-cells = <1>;
			sound-name-prefix = "m";
			port {
				adau1361_ep: endpoint {
					remote-endpoint = <&i2s2_dap_ep>;
					mclk-fs = <0>;
	i2s@2901000 {
		status = "okay";
	sound {
		assigned-clocks = <&bpmp_clks TEGRA194_CLK_AUD_MCLK>;
		assigned-clock-parents = <&bpmp_clks TEGRA194_CLK_PLLA_OUT0>;
		assigned-clock-rates = <24000000>;
		nvidia-audio-card,mclk-fs = <0>;
		nvidia-audio-card,widgets =
			"Headphone",	"m Headphone",
			"Microphone",	"m Mic",
			"Line",         "m LINP",
			"Line",         "m LINN",
			"Line",         "m RINP",
			"Line",         "m RINN";
		nvidia-audio-card,routing =
			"m LINP", "m Mic",
			"m LINN", "m Mic",
			"m RINP", "m Mic",
			"m RINN", "m Mic";
&i2s2_to_codec {
	bclk_ratio = <1>;
	srate = <48000>;
	num-channel = <2>;
	ignore_suspend;
	codec {
		sound-dai = <&adau1361 0>;
		prefix = "m";
&i2s2_dap_ep {
	remote-endpoint = <&adau1361_ep>;
I have applied the following changes to tegra_codecs.c:
diff --git a/sound/soc/tegra/tegra_codecs.c b/sound/soc/tegra/tegra_codecs.c
index 280fa41c74e9..c7d972c1aa75 100644
--- a/sound/soc/tegra/tegra_codecs.c
+++ b/sound/soc/tegra/tegra_codecs.c
@@ -28,6 +28,22 @@ static int tegra_audio_dai_init(struct snd_soc_pcm_runtime *rtd)
 	return 0;
+static int tegra_machine_adau136x_init(struct snd_soc_pcm_runtime *rtd)
+	struct device *dev = rtd->card->dev;
+    int err;
+	err = snd_soc_dai_set_sysclk(rtd->dais[rtd->num_cpus], 0, 19200000,
+		SND_SOC_CLOCK_IN);
+	if (err) {
+		dev_err(dev, "failed to set adau136x sysclk!\n");
+		return err;
+	return 0;
 static int tegra_machine_rt56xx_init(struct snd_soc_pcm_runtime *rtd)
 	struct snd_soc_component *cmpnt = rtd->dais[rtd->num_cpus]->component;
@@ -262,6 +278,8 @@ int tegra_codecs_init(struct snd_soc_card *card)
 			dai_links[i].init = tegra_machine_fepi_init;
 		else if (strstr(dai_links[i].name, "respeaker-4-mic-array"))
 			dai_links[i].init = tegra_machine_respeaker_init;
+		else if (strstr(dai_links[i].name, "adau1361-codec"))
+			dai_links[i].init = tegra_machine_adau136x_init;
 	return 0;
The codec probes, but I have no APE sound card at all. Here’s the contents of /proc/asound/cards:
# cat /proc/asound/cards
 0 [HDA            ]: tegra-hda - NVIDIA Jetson AGX Xavier HDA
                      NVIDIA Jetson AGX Xavier HDA at 0x3518000 irq 52
In r32.7.1 my amixer controls showed up under card 1 (amixer -c 1). But in r35.4.1 I can’t see anything with amixer. I’m assuming this is because the APE isn’t loading properly. What am I missing?
Wilkins
I’m thinking I may need to write a platform_driver file (e.g., tegra_sgtl5000.c). My codec only has an i2c_driver
nova@marco:~$ cat /proc/asound/cards
 1 [APE            ]: tegra-ape - NVIDIA Jetson AGX Xavier APE
                      Unknown-Jetson_AGX-NotSpecified
I added the platform driver, APE showed up, and everything seems to be working now
